fixing a steering wheel
Old Nov 8, 2013 | 07:54 PM
raverx3m's Avatar
Default fixing a steering wheel
is it possible to reattach the steering wheel cushion to the rod inside?
my ej6 steering wheel broke off the rod inside it
when the plastic part separates from the frame. dont know how else to describe it.
is there a way to glue it back to it without cutting the back?
i ve seen people cut the back with a razor and use epoxy but it leaves a hardened gap filled with epoxy on the back..
im planning to find a leather wrap for it later also to cover some outside wear.
Old Nov 9, 2013 | 03:20 PM
uberEFtuner's Avatar
Default Re: fixing a steering wheel
Drill holes, mine already had holes. Then squeeze tons of super glue in there. Then twist it to spread the glue around before it dries.
Old Nov 9, 2013 | 08:50 PM
raverx3m's Avatar
superglue holds it good? or should i use epoxy or something?
jnb0111
Dec 28, 2015 04:23 AM
civicDX2178
Jul 5, 2006 01:17 PM
Jonathan_ED3
Jul 9, 2005 09:20 AM
stripes777
Jul 5, 2003 11:38 AM
