Fuel pressure tester kit
Old Nov 8, 2013 | 08:07 AM
HondaPartsHero's Avatar
Technical Hero
Default Fuel pressure tester kit
Just trying to see if anyone has a suggestion fr a cheap fuel pressure tester kit that would work with Honda/Acuras. I was looking at the two that harbor freight sells. One is 19.99 but I'm not sure if the fittings will work with Honda threads. The other says it will but it's 89.99. I'm trying to find one that will work for Honda but not be $80. It really doesn't need to work with all models but Hondas or most imports.
http://www.harborfreight.com/fuel-in...ter-92699.html
http://www.harborfreight.com/master-...kit-97706.html
Old Nov 8, 2013 | 09:39 AM
jdmh22eg2's Avatar
Default Re: Fuel pressure tester kit
NORMALLY all kits have 2 shrader valve screw on and thy fit 99% of cars/trucks. i do belive the HF one would.
Old Nov 9, 2013 | 06:55 AM
Gunmetal_B20_Hatch's Avatar
You usually ahve to special order the fittings for Honda/Acura. They have 2 styles that I am aware of: a pulsation damper adapter, and the M6 threaded one. Later models require use of the pulsation damper adapter that isnt supplied with 99% of the kits.
EDIT: it looks like the $90 one will get you the M6 adapter, but not the damper adapter. It usually runs about $20 online.
civicservice
Apr 27, 2017 08:11 AM
DJ Gurgla GSR
Jan 11, 2012 07:34 AM
jyacoba2009
Nov 15, 2009 12:30 PM
dylokjai
Oct 26, 2004 07:59 AM
