Clutch problems but new clutch?
Old Oct 28, 2013 | 06:54 PM
DingDang's Avatar
Default Clutch problems but new clutch?
Hey guys. I have a 1996 gsr integra and it's been having this problem where after a good 20 min drive the clutch would not grab as hard when shifting. But it would grab fine before 20 mins.
And I recently just did these to my car.
New stage 1.5 competition clutch
New lightened flywheel 14lbs
Clutch master slave cylinder
Short shifter
Shifter bushings
Again the car grabs fine and chirps when I start it up. It's actually real grabby because of the new clutch. But after a seven mile drive home from work the pedal starts to have a really high engagement. And it won't grab as hard. I'm pulling in 1st gear to about 7k and slamming it into 2nd and all it would do is grab but it won't really really grab and "chirp".
Pulls fine no slipping. But I can't chirp it when it's warmed up.
I though doing a new clutch and flywheel and a pedal height adjustment would do it but no
Anything will help. Thanks
Old Oct 28, 2013 | 07:59 PM
zanklc's Avatar
Default Re: Clutch problems but new clutch?
bleed the clutch lines
Old Oct 28, 2013 | 08:01 PM
zanklc's Avatar
make sure you have no air in the lines or you clutch will feel weird
Old Oct 28, 2013 | 08:23 PM
DingDang's Avatar
Yeah I'll give that a try. Thanks.
Old Oct 29, 2013 | 04:15 PM
KidDxbOrI's Avatar
Did you do the recommended break in period ?
Old Oct 30, 2013 | 12:02 PM
DingDang's Avatar
I'm still doing it now. I'm just saying it's having the same problem before I put all that stuff in. I did a clutch bleed. It make the clutch feel a lot better but after a morning start and a 20 min ride it went back to being the same way before I did the bleed...
jdmcivicracer89
21
Jun 5, 2008 09:39 AM
dRuNkEnMoNkEy97
Sep 26, 2007 06:08 AM
TOP END MS
Dec 15, 2006 07:06 PM
delsolb16
Sep 22, 2005 08:04 PM
b20civic
Feb 1, 2003 07:38 PM
