TPS issues. NEED HELP!!!
Old Nov 3, 2013 | 10:02 AM
kilerintegra's Avatar
Default TPS issues. NEED HELP!!!
I have a 90 Integra and my ECU was throwing the TPS code. I got a brand new one and when I tried to install it, it made my throttle stay open to where it idled at 2500rpms at temperature.
Why is this? I cant adjust it any further but I can push the throttle back with my and and it idles perfectly, but once I let go it goes right back up
Old Nov 3, 2013 | 12:54 PM
motoxxxman's Avatar
Default Re: TPS issues. NEED HELP!!!
sounds like you installed the sensor wrong
Old Nov 3, 2013 | 05:08 PM
Yeah you were right I took the throttle body off and figured it out. Next question, my car would not stop idling high, I unpluged the iacv and now it idles great. Can I run my car without that or should I replace it???
Old Nov 4, 2013 | 01:53 AM
HondaPartsHero's Avatar
Technical Hero
Did you adjust the TPS?
https://honda-tech.com/forums/showth...131&styleid=14
https://honda-tech.com/forums/showth...986&styleid=14
Old Nov 4, 2013 | 03:46 AM
motoxxxman's Avatar
do ^that^ first. then go through the procedure of setting ignition timing and idle speed via the idle screw.
Jeeptech
May 19, 2017 08:12 PM
brandynEG
Engine Management and Tuning
13
Sep 27, 2013 04:51 AM
BIGef
Jul 22, 2013 10:01 AM
crxb16a90
Nov 18, 2009 06:47 PM
si90rex
Mar 30, 2006 12:54 PM
