B18b won't start! I'm desperate..
Old Nov 26, 2013 | 07:51 PM
santii7's Avatar
Icon2 B18b won't start! I'm desperate..
Okay. So I swapped in a b18b Into my 98 ek hatch after I blew my single.
It will crank but it won't start, I'm runnin my stock obd2a harness, same harness I used on the single (it worked just fine on the single), brand new distributor, and p75 obd2a ecu.
I did the crank sensor bypass. My cels are o2 sensor 1 and 2 (bc there is no bung on the headers or my exhaust) and water temp sensor.
I do have spark and I do have fuel also. My grounds are all good, my fuses are all good, I tried several spark plug wires, spark plug are gapped correctly, my firing order is correct (1-2-4-3), I tried 2 p2e ecus and the p75. The motor is on timing. Compression starting from cyl one is 180,180,150,180.
Here's the weird part.. If I put the firing order backwards (4-3-1-2) it does start but it runs horrible like its completely off timing bad.
Am I missing something?! I'm going crazy, I'm desperate at this point lol I don't understand! Can somebody please help me here 😭
Old Nov 26, 2013 | 10:30 PM
n/a2boost's Avatar
Default Re: B18b won't start! I'm desperate..
This is how your firing order should be.
Old Nov 27, 2013 | 03:08 AM
santii7's Avatar
That's how I got it 1-2-4-3
Old Nov 27, 2013 | 06:41 AM
fcm's Avatar
fcm
Old Fart
What is the fuel pressure?
Are you using an HEI spark tester when checking spark?
if not do so. 94
Old Nov 27, 2013 | 08:53 AM
santii7's Avatar
I solved the problem..
After 2 days of days of headache and no sleep.. Turns out that my brand new distributor was fxckin 180 degrees off smfh.
Thank you guys for the replys!
Johncivic3
May 20, 2013 04:14 PM
julianbc2
Jun 8, 2011 02:52 PM
gsrboost737
Apr 16, 2009 11:38 PM
sik96teg
Mar 11, 2006 10:50 AM
.one lane
Oct 17, 2005 07:40 PM
