Broken plug: Need info
Old Nov 19, 2013 | 11:43 PM
CyberC1ren's Avatar
Default Broken plug: Need info
Okay so as I was wiring up my mini-me, dpfi to mpfi today I noticed this...(referr to pic below)
I know it broke recently as my car hasn't been running for a few days. Can anyone tell me what this sensor is? There were a red an black wire coming from the plug, not sure if it's solid red or not but it looked like it. I believe it is the fan switch but I'm almost positive that's wrong lol. Any help Is welcomed. OH it's a d-series obviously, I noticed the same plug location on my Y8 head so I assume it's something the common for all D Series motors. Thanks ya'll!
Old Nov 19, 2013 | 11:45 PM
CyberC1ren's Avatar
Default Re: Broken plug: Need info
I just noticed the picture is cocked sideways, it looks like the right side is supposed to be the bottom, the left is the top.
Old Nov 20, 2013 | 01:40 AM
HondaPartsHero's Avatar
Technical Hero
ECT sensor (TW sensor), sends temperature signal to the ECU
Old Nov 20, 2013 | 11:39 AM
CyberC1ren's Avatar
So it's the sensor that sends a signal to my dash temp guage? And thanks a lot
Old Nov 20, 2013 | 11:50 AM
kyden's Avatar
No. It sends the signal to your ecu. The one next to it with a single wire is for your gauge.
Old Nov 21, 2013 | 01:17 AM
CyberC1ren's Avatar
Okay then I take it it's a bad idea to leave it off then? I don't totally understand why the ECU would need that signal besides to turn the fan on? Care to shed a little bit of light on that?
Old Nov 21, 2013 | 02:42 AM
Fliptard's Avatar
there are 3 temp sensors
Single wire on head - Gauge cluster
2 wire next to it on head - To ECU
same plug with 2 wires on Thermostat housing - turns on fan
Old Nov 21, 2013 | 05:13 AM
kyden's Avatar
The ecu needs a coolant temp signal to go into closed loop. (google it)
Old Nov 21, 2013 | 07:49 PM
CyberC1ren's Avatar
I have googled it haven't really came up with much.
And thanks fliptard that's what I was looking for. I have manually activated fans so I can take that plug from the thermostat housing! Thanks guys for the help:D
Old Nov 22, 2013 | 06:58 AM
kyden's Avatar
http://www.modularfords.com/threads/...p-vs-Open-Loop
Old Nov 23, 2013 | 02:59 PM
CyberC1ren's Avatar
That's actually really good info. I found another one that just basicly said "It tells the ECU if the motor is hot or cold and helps adjust the fuel." That thread you just posted goes into extreme detail! Thank you really good knowledge there.
Old Nov 23, 2013 | 03:11 PM
CyberC1ren's Avatar
Also I am wiring up the plug from the switch that turns on the rad fan, the colors for that one at grey and light green, and the one for the open/closed loop temp switch are dark green/yellow and red/yellow, does anyone know what color is top or bottom?
jemo1
Jun 5, 2013 05:55 PM
WhiteTrashedDA9
Mar 20, 2013 07:08 AM
Creator
Mar 11, 2010 05:29 PM
skUnK2jdm
10
Feb 9, 2008 10:00 PM
MOVE OVER
19
Dec 17, 2005 11:48 PM
