cam caps question
Old Nov 17, 2013 | 06:36 PM
boostlsveg's Avatar
Default cam caps question
Ok guys so I got my motor together n in the car. But I read on here that if u change the cam caps u have to have it line honed n I wasn't aware of this till now. Well my problem is that I had two heads laying around for awhile n its possible that I got the cam caps mixed up im not really sure, since I didn't know this I didn't make it a point to keep them seperate. So now that I know this im worried. my question is what can I do to check n make sure I don't need to have it line honed? Thanks for any help
Old Nov 17, 2013 | 07:23 PM
Bouckaroo's Avatar
Default Re: cam caps question
You might be able to gather them all up and look for numerbs on them to see which ones are matching set.
This is something i have always been careful of as mixing them up can be bad.
Also, if you hone those caps, you change the relation of the cam to the crank. Im certain there is a very very small tolerance, as even light scoring can render them useless.
Old Nov 17, 2013 | 07:26 PM
10psiLsEf2's Avatar
Youll be ok
Old Nov 17, 2013 | 07:51 PM
boostlsveg's Avatar
well I sold my other head so I no longer have the other ones. Another reason y I need to figure this out so I can let him know so he doesn't end up messing up his motor. But I do know for sure these r matching caps they just might b from the other head. They were stored separately I just don't know which ones went to which head. Thanks for the reply.
Old Nov 18, 2013 | 09:26 AM
motoxxxman's Avatar
best way to tell is to just remove the cams and put all the caps back on without the cams, then look and feel with your finger how the bore of them lines up with the bore on the head. if they feel dead smooth at all points on every cap, you have the right ones on the head. if any of them feel like they have a lip, aka are slightly off-center, they are the wrong caps.
Old Nov 18, 2013 | 04:07 PM
boostlsveg's Avatar
ok well if they don't line up perfectly, what would I have to do get it line honed?
Old Nov 18, 2013 | 04:49 PM
fcm's Avatar
fcm
Old Fart
Take cams/head/caps to machine shop and have them do the line boring/honing, it's not something you want to get wrong, and no you will not be OK, [dumb advice]. 94
Old Nov 18, 2013 | 04:52 PM
boostlsveg's Avatar
ok yea I wasn't gonna try my self I figured my machine shop. Thanks
Old Nov 18, 2013 | 05:00 PM
10psiLsEf2's Avatar
Sorry for spreading false information.
Hey fcm is there a way to platiguage the cam caps? Before deciding to get it aline honed?
I checked a helms for integra. But that didnt show nothing.
Old Nov 21, 2013 | 07:28 PM
B(eighteen)C's Avatar
youll be ok. but for sure to get the best out of your motor or your head in this case, is to get a line hone. i remember switching mine (on a z6 head so i didnt care) and took the head in to get it resurfaced and the shop would not do it cause of all the scaring from cam shaft. they asked what kind of work ive done and i told em i had switched out the cam caps cause i broke something (i forgot what). and they said that each cam cap is machined for each head and should not be switched between heads
Old Nov 22, 2013 | 04:16 AM
boostlsveg's Avatar
Well im gonna check mine this weekend if I can n if it feels/looks like they're not lining up im gonna send them to the boy that bought my other head n he will send me the other ones. It would save both of us issues If we do got them switched. I've already let him know what's going on. Thanks for the replies
Old Nov 24, 2013 | 07:37 PM
boostlsveg's Avatar
Caps r deff wrong... Sending these caps to the guy that bought my other head n he's sending those back. Thanks for the help guys
Old Jan 29, 2014 | 09:27 AM
boostlsveg's Avatar
Figured I would update this thread. I sent the guy the caps I had n he was supposed to send me the ones he had n I never got them. So either he beat me or usps lost them, I really don't know. So now I got an itr paperweight so I'm in the process of getting another head. This blows big time.. It's a big set back cuz I been waiting since the end of nov for them to come n now I gotta pull the head n get new studs n head gasket. N also when I get this other head I'm gonna atleast get new seals n a valve job n possibly guides, which I already did to the other head. Ugh anybody know if it's possible to reuse my new bronze guides that r in this itr head?
B_Swapped93
May 21, 2013 07:50 AM
deepfriedjinx
Jun 19, 2011 06:36 PM
ImaHondaLover
Jan 29, 2008 12:21 PM
freeagent32
12
Jul 13, 2005 03:55 PM
216.226.142.95:27016
Jun 27, 2003 10:22 PM
