Strange ignition problem - civic
Old Dec 12, 2013 | 02:25 PM
coreyBWA's Avatar
Default Strange ignition problem - civic
Okay so i have a 94 civic its been my daily driver for a year and a half now with no real problems
but now when i turn off my car my fog lights stay on, and my air keeps blowing. i would say something was mis wired but nothing has changed and this just randomly started now.
any help would be appreciated.
thanks
Old Dec 13, 2013 | 01:30 PM
coreyBWA's Avatar
Default Re: Strange ignition problem - civic
bump
Old Dec 14, 2013 | 10:53 AM
coreyBWA's Avatar
bump, sucks having to unplug my battery everytime i get out of the car
Old Dec 14, 2013 | 04:23 PM
ej1995's Avatar
You have a short circuit condition or something wired incorrectly. Start tracing the wiring on the circuits that stay powered.
Old Dec 14, 2013 | 09:27 PM
MisereNoire's Avatar
Also, get yourself the FSM, be it in .pdf or physical and check the wiring diagrams to see what relays run inline with the systems that are remaining powered...then pull the relays and bench test them...sounds like you might have a relay frozen in the powered position.
Old Dec 15, 2013 | 12:47 PM
coreyBWA's Avatar
i can swap a engine but i have no clue about electronics, i dont even know the first place to start
Old Dec 15, 2013 | 01:16 PM
2kdrift's Avatar
maybe a short in the ignition itself? try unplugging it and go from there
Old Dec 16, 2013 | 01:29 AM
coreyBWA's Avatar
where am i unplugging the ignition from? i disconnected my fog lights and took my radio out still no luck
Old Dec 20, 2013 | 12:49 AM
engineerings's Avatar
Did you check the fuse?
Old Dec 20, 2013 | 10:52 AM
maboosted lude's Avatar
check all fuses .
Old Dec 21, 2013 | 09:27 AM
fcm's Avatar
fcm
Old Fart
A bad fuse is not going to keep the ign./acc. circuit on.
As has been mentioned, either a "short" from a 12V+ constant to the ign./acc. circuit or a bad ign. switch.
Remove the column cover assy. [14/15] and the drivers lower instrument cover, [14] so you can see the ign. switch harness...
http://www.hondaautomotiveparts.com/...STRUMENT+PANEL
see if there is an alarm or remote start, [you do not know about] wired to the harness and/or follow ign. switch harness to there plugs and unplug them...
Name:  94 civic ign, switch harness.bmp
If there is an alarm/remote start wired in, try unplugging it, if unplugging it solves problem, remove it completely, [all wiring] if unplugging the ign. switch solves the problem, replace the switch. 94
Old Dec 31, 2013 | 06:33 PM
hybridmiklo's Avatar
engine swaps are easy. A monkey can do it. Electrical is where you make your money. Located in socal? Pay me and I will take care of it for ya
Old Jan 7, 2014 | 06:51 AM
johnsaidgo's Avatar
bump
sscivicsi
Honda CR-V & Element
Mar 30, 2016 06:16 PM
92 civic ex 4dr
Feb 14, 2015 09:09 AM
Double_Dk
10
Feb 2, 2005 05:11 PM
Spartanic
Jan 6, 2003 09:43 PM
