compression #s? b20 vtec
Old Dec 5, 2013 | 01:21 PM
killer833's Avatar
Default compression #s? b20 vtec
stock b20/pr3 head so i noticed excessive oil on the VC breather. I just ran a compression test and these are the results. (tester is a loaner, so I'm not banking on accuracy, but it at least shows the variance)
#1 - 150psi
#2 - 125psi
#3 - 125psi
#4 - 150psi
Now i have already read about wet and dry testing which i will do, as well as check the valve lash. But what is the likelyhood i actually have damage on two cylinders, both getting very similar results. The other thing ive read is possibly blown head gasket as well? the car also runs strong.
Old Dec 5, 2013 | 07:54 PM
slowcivic2k's Avatar
Default Re: compression #s? b20 vtec
Excessive crankcase pressure is generally a sign of poor sealing in the bore. Make sure the PCV valve still functions and is not stuck.
Provided you conducted the compression test correctly, your engine definitely has wear.
Add a tablespoon of oil to the bores and retest the compression. You could have a problem between 2 and 3.
Any problems with the way it runs?
Old Dec 5, 2013 | 07:55 PM
F22Master's Avatar
did you do the test with the throttle open?
Old Dec 5, 2013 | 09:11 PM
killer833's Avatar
the b20 does not have a PCV system on the block, and the car did not come with catch can (i bought it with the swap). I plan to re test it tomorrow, throttle open and do a wet test. When you say a problem between 2 and 3, what possibly between? I've read it could be the head gasket due to the the same pressure results on those cylinders.
Old Dec 6, 2013 | 07:03 AM
EpHatchy's Avatar
your rad overflow bottle would be full if that was the case from the pressurized coolant.
Old Dec 6, 2013 | 10:54 AM
killer833's Avatar
thanks, i havent checked it, but i will now.
Old Dec 6, 2013 | 11:01 AM
F22Master's Avatar
Was the first test with the throttle open or closed? If closed, then the numbers aren't that bad, but you must re-test with the throttle open to be sure. Also, the closer to operating temp, the better the test will be. A warm valve cover is good.
Old Dec 6, 2013 | 06:21 PM
All engines displace air in both directions, if you do not have a manifold vacuum source pulling a draft on the crankcase, you will blow seals, and throw oil out of any place that it can, including the dipstick.
lsvtechatch92
Nov 1, 2006 11:51 AM
JDM97EK
Oct 28, 2006 09:12 PM
B20TDC2
Jul 30, 2005 03:20 PM
ILOVEGIRLS
Oct 11, 2001 08:54 PM
