oil light help!
Old Oct 27, 2013 | 07:29 PM
94whitecivic's Avatar
Default oil light help!
hello my everyday 95 gsr b18c1 all stock integra oil light keeps coming on after i start it up. the light will stay on for about 5-10 seconds then flicker off and does not come back on until i turn it back off and let the car sit for a few min. i have just replaced the oil pump all bearing in the bottom of the motor, timing head gasket. and the light is still doing the same pls help thanks.
Old Oct 28, 2013 | 07:20 AM
h2.4's Avatar
Default Re: oil light help!
put a oil pressure gauge in and see what your oil pressure is at. That is the first step.
Old Oct 28, 2013 | 02:50 PM
oil pressure builds in about 1 second and is around 40 psi
Old Oct 28, 2013 | 02:52 PM
i also swapped out the sending unit again and nothing changed
Jman8108
May 23, 2010 09:32 AM
hbyrd8701
Apr 6, 2010 12:52 PM
user 93082343
14
Mar 30, 2009 10:34 PM
Funkin Flux
Mar 17, 2006 10:12 PM
