b16 head with unknown cam caps
Old Nov 8, 2013 | 01:50 AM
civic-one's Avatar
Default b16 head with unknown cam caps
I have a b16 head with ctr cams. Im having hard time finding the tdc for the cams. The holes for the cam caps are on the side. Something ive never seen before on a vtec head. Can someones help me identify the caps if its the right one or not.Ill be able to post pics later. Still trying to find my camera. Thanks.
Old Nov 8, 2013 | 02:07 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: b16 head with unknown cam caps
What? From my understanding, the cam caps are numbered, and for tdc you put everything down, amd you line up the cam gear markings are facing each other, and the words up shoud be perpendicular to the timing marks on the timing belt cover
Old Nov 8, 2013 | 03:14 AM
civic-one's Avatar
See how those holes are on ths side instead of in the middle to lock the cams so it wont be able to move.
Old Nov 8, 2013 | 06:42 AM
kyden's Avatar
looks like an obd0 head.
Old Nov 8, 2013 | 12:46 PM
civic-one's Avatar
Ahuh!!! I think youre right. The head has ctr cams and somehow im having a hard time findinv tdc on this because the cam gears arent both pointing up if I follow the holes for the tdc on the caps. Intake side is a little off.
Old Nov 8, 2013 | 12:58 PM
Ferio Wdm Edition
Im getting a bit lost as to what you are saying..if the intake cam is off, why wouldnt you lock the cam down, then spin the cam with cam gear bolted up, and spin with a big set of channel locks or something?
Old Nov 8, 2013 | 01:14 PM
EpHatchy's Avatar
since you have ctr cams in a older style head your not goin to be able to lock the cams in place. your going to have to line up the gears at tdc and crank at tdc to get timing belt timing correct.
ive never used those holes to lock anything in place even the last time I did my timing belt just make sure cam gears are at the right spot and crank is at the right spot.
Old Nov 8, 2013 | 01:24 PM
EpHatchy's Avatar
do it like this. how I do mine.
Old Nov 8, 2013 | 01:32 PM
Ferio Wdm Edition
How do you guys know if its a older style b16 head? What gives it away?
Old Nov 8, 2013 | 01:40 PM
EpHatchy's Avatar
the rails on top of cams.
Old Nov 8, 2013 | 01:58 PM
Ferio Wdm Edition
Ok what about them though?
Old Nov 8, 2013 | 06:28 PM
civic-one's Avatar
Thisis exactly what I was thinking. I tried aligning the holes and locked the cams and cam gear was off. So did a little reading and came up empty handed. So dont go with the cam holes and just tdc the cams using the cam gear? What if i go out and purchase cam caps thats from a newer b16. Will this work out?
Old Nov 10, 2013 | 09:50 PM
civic-one's Avatar
Up top!!!
Old Nov 11, 2013 | 05:37 AM
kyden's Avatar
the rails. on the obd1 + obd2 heads the rails have a machined finish. the obd0 have that bare cast.
Old Nov 11, 2013 | 10:34 AM
EpHatchy's Avatar
I don't think you want to be swapping cam caps from another head Unless you want to line hone your cam journals to make sure their round.
FWIW even when the cams are locked in place there's still some room for error.
blaak-crx
18
Dec 8, 2013 08:39 AM
ThefirstPACT
Mar 19, 2008 12:27 PM
nexgen91
Jan 21, 2007 10:19 AM
botlebruiser
Mar 31, 2006 10:39 PM
tegrakid
Apr 15, 2003 04:55 PM
