97 del sol wont idle when cold
Old Oct 23, 2013 | 09:48 PM
WillU's Avatar
Default 97 del sol wont idle when cold
I am working on a 97 del sol with the y7 engine it smokes and wont idle you have to keep feathering the throttle to keep it running then when its warm it idles just fine and doesnt smoke what could this be?
Old Oct 24, 2013 | 01:07 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 97 del sol wont idle when cold
Did you ever have to add coolant? Check engine light on?
Old Oct 24, 2013 | 02:02 PM
WillU's Avatar
I havent added any coolant and cel is not on
Old Oct 24, 2013 | 02:31 PM
WillU's Avatar
Also sometimes it will die when its cold and white smoke will come pouring out the throttle body
Old Oct 25, 2013 | 01:02 AM
holmesnmanny's Avatar
what do you mean coming out of the throttle body ? your issue could be the engine coolant temperature sensor or even the fitv could be bad
test it for ohms with the car completely cold should be 2000-2500 ohms...with the car completely warmed up it should be 180-250
Old Oct 26, 2013 | 11:06 AM
WillU's Avatar
White smoke will come out of throttle body if its cold and dies
Old Oct 27, 2013 | 05:52 AM
motoxxxman's Avatar
do a compression test and leakdown test when cold and when hot. might have a blown headgasket. or the rings could be cooked.
take the sparkplugs out, post an up-close pic of the tips of them all.
Old Oct 28, 2013 | 11:11 PM
WillU's Avatar
Figured out the problem the gas station he got gas from put diesel fuel in the premium tanks so it had diesel in the car
Key Enzyme
Feb 15, 2013 06:08 AM
Neptronix
Feb 1, 2008 02:53 PM
iatetoes
Jul 13, 2004 04:43 AM
