Does this sound right?
Old Nov 14, 2013 | 06:15 PM
dwashy21's Avatar
Icon7 Does this sound right?
I've got a d16z6 that I just swapped into my coupe, all I did is replace the d16z6 that was already in there. Anyways, does this idle sound right? I've got a bud who thinks it might be misfiring or that somethings wrong internally. What do you guys think?
All it has done to it that could affect engine performance is an intake, high flow cat, and cat back exhaust (apexi ws1).
Old Nov 14, 2013 | 08:38 PM
dwashy21's Avatar
Default Re: Does this sound right?
Bump
Old Nov 15, 2013 | 05:28 AM
dwashy21's Avatar
bump
Old Nov 15, 2013 | 05:54 AM
kyden's Avatar
it does sound off. why? i can't tell from a short clip.
Old Nov 15, 2013 | 05:56 AM
dwashy21's Avatar
Do you think it could be a timing issue? And yea sorry its a poor video
Old Nov 15, 2013 | 04:12 PM
10psiLsEf2's Avatar
Sounds like a misfire. It could be timing,dead injector,plugs,wires,compression,bent valves.
Start by identifying what cylinder is misfiring by startibg.
Open hood
With engine on remove 1 spark plug wire at a time. When doing this you should notice your engine stumble. If you dont notice a change on a certain cylibder. THATS the cylinder that is misfiring.
Old Nov 15, 2013 | 04:33 PM
motoxxxman's Avatar
Do some basic maintenance. most importantly: valve lash adjustment. then replace the plugs, wires, cap, and rotor. problem solved
Old Nov 15, 2013 | 04:37 PM
10psiLsEf2's Avatar
Dont buy plugs,wires,cap,rotor. If you do and it turns out to be a bent valve,worn rings,injector then you justvwasted 200 dollars taking a wild guess at the problem.
Idk about other people but i like to pin point abd diagnose issues before buying parts :-)
Old Nov 15, 2013 | 04:40 PM
dwashy21's Avatar
Yea thanks guys for all the input! I'll determine which cylinder is misfiring later tonight or tomorrow, hopefully it's not a bent valve because I just bought this motor a week ago! In the mean time, is it OK to drive while I've got a misfire?
Old Nov 15, 2013 | 04:43 PM
10psiLsEf2's Avatar
Further damage could be made if you drive
Old Nov 16, 2013 | 11:28 AM
dwashy21's Avatar
OK I did the test and isolated the misfire to cylinder 4. I checked the spark plugs and switched them out so that's not the problem. The injectors are fine I did the screwdriver test and they are all functioning. My next guess is timing on the distributor. Does that seem like a possibility?
Old Nov 16, 2013 | 02:33 PM
motoxxxman's Avatar
no. that would affect all 4 cyls evenly.
do a valve lash adjustment like I said above
Old Nov 17, 2013 | 08:54 AM
10psiLsEf2's Avatar
So injectors,plugs are good.
Now do a compression test. If ypu dont have the tool you can rent it at autoparts stores.
Also check #4 sparkplug wire for corrosion.
Old Nov 17, 2013 | 02:16 PM
dwashy21's Avatar
Alright I'll be doing valve lash adjustment this Tuesday, and I ran a compression test earlier today. The problem cylinders are 2 & 4.
Here is cylinder 2:
And cylinder 4:
Old Nov 18, 2013 | 09:23 AM
motoxxxman's Avatar
your gauge is missing the shrader valve. the gauge should not jump up and then back down, it should jump up and stay up, staying at the highest pressure it reads throughout the test. that's an issue with the gauge, not your car.
Old Nov 18, 2013 | 05:03 PM
Gunmetal_B20_Hatch's Avatar
X2... Looks like the gauge is setup for a rotary. lol. Put the schrader valve back in.
Old Nov 18, 2013 | 06:39 PM
dwashy21's Avatar
I knew something was up with the tester that's why I took a video lol. What does the schrader valve look like? I've been using O'Reillys tester kit and the only other thing in the box is another end to screw into the spark plug hole.
Old Nov 18, 2013 | 08:21 PM
b20vteg757's Avatar
Shrader valve hehehe
Old Nov 20, 2013 | 05:09 AM
motoxxxman's Avatar
^lol^
Schrader valve is a needle valve, looks kinda like the needle valve in a tire stem.
Old Nov 20, 2013 | 05:11 AM
motoxxxman's Avatar
looks like this, and goes in the end of the hose
Old Nov 20, 2013 | 10:08 PM
dwashy21's Avatar
Yea O'Reillys kit definitely did not have that valve, I'll go to AutoZone tomorrow and retest
Old Nov 21, 2013 | 04:22 AM
jdmjunkieXL's Avatar
did u make sure the firing order was correct at the dizzy??
Old Nov 25, 2013 | 06:22 PM
Slow money's Avatar
Definitely your dizzy
Old Dec 2, 2013 | 07:18 AM
dwashy21's Avatar
I didn't get around to the compression test, but I did replace the top piece of the stock exhaust manifold which turned out to be cracked! Idle got a little bit better , but it's back again. I know I need to do a compression test again, but now I'm thinking that maybe my car is running rich. I looked up other videos of civics running rich on YouTube and they all sound similar to mine
Look @ 0:53
kingmickez25
Oct 20, 2012 04:05 PM
EG-SIXV-TEC
Sep 6, 2010 05:12 AM
BYT
Jun 28, 2003 04:57 PM
MysteryWagon
May 4, 2002 04:38 PM
