Parking brake light won't go off after changing drums.
Old 06-22-2014, 04:17 PM
woodenchef's Avatar
Default Parking brake light won't go off after changing drums.
Today I changed my drum brakes. After adjusting the drums breaks so there was a slight drag. I put everything back together and went to adjust my parking brake. I noticed the parking brake light was on while the handle was (fully down). When I raised in the parking brake light brightens a tad bit, but when I put it back down it dims a bit, but still does not shut off. What could of caused this was working fine before?
Old 06-23-2014, 11:38 AM
DCFIVER's Avatar
Default Re: Parking brake light won't go off after changing drums.
Check the brake fluid level. Sometimes the float on GM trucks gets stuck at the bottom......
Old 06-23-2014, 11:59 AM
woodenchef's Avatar
Yeah, today I looked, and my fluid level was low. I forgot to top it up the last when I bleed the last cylinder. Then when I got in my car put the e-brake down the light went off. So the float in the master, will send a signal to your car when the fluid level is low? I did not know that. At least on a older car this age.
FK00GSR
11-07-2003 12:32 PM
94BlackRS
11-28-2002 02:43 PM
Slow
10-29-2002 03:38 PM
SlowazzGSR
06-07-2002 10:30 PM
hybridbmw
02-19-2002 10:38 AM
Quick Reply: Parking brake light won't go off after changing drums.
