honda b16 distributor
Old Jul 8, 2014 | 01:40 AM
ninju's Avatar
10 Year Member
Default honda b16 distributor
so i have one b16a original distributor with part number td-44u.it has a burned module and coil.i am trying to buy one (used) in my country but i can only find the newer obd2 distributor which has one fuse in staid of 2.i searched and found that i can convert the fuse to other two like my obd1 and it will work fine,but in staid of modifying the obd2 i prefer to rebuilt my original obd1.so i disassemble them and they almost look identical,the coil on the obd2 is exactly the same with the obd1,same part number etc.the one am not sure is the icm (ignition module),the obd1 has an OKI MNE-303 G2304J and the obd2 has a Hitachi E12-303 but i was not able to remove it and check the part number.Is the ICM interchangeable on obd1/obd2?It SHOULD be if you think that by modifying the fuse on the obd2 it can work perfectly on an OBD1 setup.Please Help.
ej8_fredi
Mar 28, 2009 11:10 PM
specie
Jun 14, 2004 06:32 PM
