90 integra won't start
Old May 25, 2014 | 03:55 AM
Bobdontwork's Avatar
Default 90 integra won't start
Ok so I was driving it ran fine then I got to a red light then it died wouldn't start pushed to a parking lot it started but the rpms jump from 1 to 0 then died haven't startd sense put in a new fuel pump and fuel filter and new spark plugs and still noting it's getting fuel and spark.. Don't no what's keeping it from starting
Old May 25, 2014 | 04:11 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 90 integra won't start
Is it throwing any codes?
Old May 25, 2014 | 04:39 AM
Code6 but I don't think that woul make it not start maybe a bad map tho?
Old May 25, 2014 | 05:14 AM
The Grumpiest
What do you mean a bad MAP? Is this car modified?
Old May 25, 2014 | 09:19 AM
No it ur air and fuel ratio tells u how much it needs of both
Old May 25, 2014 | 11:14 AM
The Grumpiest
No kidding. How did you come to the conclusion it might be a bad MAP? Why would it be a bad MAP? If the car is not modified they don't go bad. It doesn't sound like you've done much troubleshooting.
Does it crank but no start? No crank? What color is the spark? CEL come on for 2 second when car is started? Are you throwing any codes? Injectors spraying fuel?
Provide more information than you have if you want serious help.
Old May 25, 2014 | 12:20 PM
Cranks got spark and car does have to be modified for it to go bad and a code 6 but that wouldn't make it not start tho
Cel stays on
Old May 25, 2014 | 12:28 PM
The Grumpiest
I'm out. I'm not going to pull teeth getting you to answer all the questions I asked.
Old May 25, 2014 | 01:29 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Wut?!?
A gas internal combustion engine needs 3 things to run = spark, fuel, and compression. Some people like to break it down further but those are the basics. Until you check the last one you can't rule out engine issue. If you have a code for the MAP sensor then I suggest you get out a DMM and start troubleshooting the wiring.
d15bflat
Jul 7, 2009 12:29 PM
supermario680
Sep 26, 2008 04:14 PM
LsVtakYO
Jan 18, 2006 01:15 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
