b18a1 injectors replacements?
Old May 30, 2014 | 01:06 PM
br8crumb's Avatar
Default b18a1 injectors replacements?
obd0 ls swap in my civic. got 1 bad injector but looking to replace set. besides oem from dealer if they still sell for dumb money... what else will replace a oem fuel injector and is good quality??
Old May 30, 2014 | 01:09 PM
Fliptard's Avatar
Default Re: b18a1 injectors replacements?
ALL B series injectors are the same 240CC, as well as most D series EXCEPT a D16y7. Just make sure you get OBD0/1 injectors.
Old May 30, 2014 | 01:30 PM
dderolph's Avatar
Since you're trying to minimize cost, why not just replace the defective one?
Old May 30, 2014 | 08:00 PM
br8crumb's Avatar
isnt really about minimizing cost. just rather not pay dealer prices lol. and injectors from a b18b1 obd1 would work....? isnt like the a1 saturated or some shiz
Old May 30, 2014 | 08:52 PM
m4xwellmurd3r's Avatar
Obd0 injectors are peak and hold. Obd1 are saturated
Obd0 are low impedance obd1 are high impedance
To use obd1 injectors on obd0 cars you need to delete the resistor box and hook the 5 wires on the resistor box together.
Never use obd0 injectors without the resistor box. It will burn out the ecu.
Obd1 pigtails are slightly different. To use obd1 injectors on obd0 harnesses you need to cut/melt/grind little notches in the plug. If you compare the two youll see what I mean
Old Jun 1, 2014 | 10:00 AM
br8crumb's Avatar
^ very informative ty
surkitroller
Dec 29, 2009 12:58 PM
CRX44
Aug 31, 2009 11:13 PM
atarigamer01
13
May 20, 2008 09:23 AM
hondacivic90zc
Mar 6, 2007 06:02 PM
si 1
Mar 10, 2006 05:23 PM
