99 GSR Idle and Misfire Problem
Old Jun 13, 2014 | 09:14 PM
dopedb2's Avatar
Icon2 99 GSR Idle and Misfire Problem
Hello... First of all I have a 99 GSR that will sometimes crank up and run fine and then when it gets to temperature at idle the rpms will jump up and down from like 750-500 like it wants to die. Not always but lately the motor has been misfiring in cylinder four and it sounds like something is wrong with my timing belt. I am replacing it soon and I hope this is the problem if anyone has any suggestions or know the problem please let me know as soon as possible. Thanks for reading...
Old Jun 14, 2014 | 05:35 PM
dopedb2's Avatar
Default Re: 99 GSR Idle and Misfire Problem
Bump
Old Jun 14, 2014 | 07:00 PM
br8crumb's Avatar
uuhh... 1 cyl misfire usually is only a 50rpm drop.. could be a bad plug or wire honestly. pull the spark plugs and see if the 1 cyl thats misfiring is any different then the other 3. and timing belt wouldnt cause just 1 cyl to **** up.
petronila
11
May 3, 2012 09:16 PM
StevenGunn
Nov 21, 2010 03:23 PM
civicsir94
Apr 2, 2009 05:04 PM
nek0
Mar 20, 2003 12:39 PM
