bad wheel bearing?
Old Jul 18, 2014 | 08:56 PM
lerks909's Avatar
Default bad wheel bearing?
When applying the brakes I hear a loud screeching noise and when i'm not applying the brakes. I know when your brakes go out ull hear the same thing but whats the symptoms of a bad bearing?
Old Jul 18, 2014 | 09:09 PM
UncleD's Avatar
Default Re: bad wheel bearing?
A bad wheel bearing is typically like a gravel grinding sound coming from your wheel well. Not usually a high pitch squealing noise.
You could have some debris trapped inside the caliper, like a rock or something, or your pads could be so low that the indicator is in constant contact with the rotor.
Can you tell if it's coming from the back or front? What kind of car is it? Rear disc or drum?
Old Jul 18, 2014 | 09:14 PM
lerks909's Avatar
I have a 92 civic lx its coming from the front wheels I just bought some brake pads less then a year ago but then again its my dd ..it sounds really high pitch screeching noise even when im turning to
Old Jul 18, 2014 | 09:16 PM
acmoc's Avatar
bad wheel bearing is easy
at speed you hear a rythm
parked, the wheel will have play both hands at 9 and 3 o clock, rock the wheel. It will shift.
Jack the suspect wheel up and spin it, you might hear it
Sounds like metal rollers
Old Jul 18, 2014 | 09:17 PM
acmoc's Avatar
bad bearing causes slight vibration
Sometime brakepads lose their retainers or backing clips, can cause a screech.
Old Jul 18, 2014 | 09:19 PM
lerks909's Avatar
I don't hear that must be my brake pads then dam duralast!
Old Jul 18, 2014 | 09:22 PM
lerks909's Avatar
I'm going to check it out tomorrow morning
Old Jul 18, 2014 | 09:23 PM
acmoc's Avatar
Oh yeah man.
OEM>Napa>carquest>Kraken/oreilly>walmart>autozone
We have contract with Napa, used to have one with Carquest too.
Napa also stocks OEM parts at times.
Old Jul 18, 2014 | 09:31 PM
lerks909's Avatar
Where should I get some good brake pads I iknow honda dealer is going to be exspensive
Old Jul 19, 2014 | 01:24 PM
Bently_Coop's Avatar
Steve at Heart
I like the Hawk HPS, they are pretty stout. Your Duralast probably have some type of warranty though, I would look into that.
Autozone isn't all bad either, I recently bought a IACV for a 98 D16y7 and it was a Denso in a Duralast box. Cheaper than everywhere else and same as OE on the car.
Old Jul 19, 2014 | 06:53 PM
acmoc's Avatar
Dealer pads are not that expensive, and they last really long
Try majestichonda,com if you have time to wait for shipping
verycleanhatch
Suspension & Brakes
Sep 29, 2009 07:32 AM
schpiel
Sep 17, 2007 07:28 PM
Spectrum24x
Mar 2, 2006 09:41 AM
jaydm ferio
Jan 23, 2006 07:42 PM
Padronis
May 2, 2002 05:40 PM
