refitting valves quertion. (grinding paste)
hello everybody
i need to grind my valves in with grinding paste.
i got the CHEMICH-O GRINDING PASET. it has two "types" of paste in it
"coarse this end" and "fine this end" which one with which one i need to do the first grind... ?
thanks
thanks
I would start with the fine so that you can see how the valves are sitting. than if you have a thin area hit it again with the course to try to cut it in more. Than go back to the fine for a final touch up.
If you are asking how to do it. I put a small amount on the valve and than place the valve back in the head. spin it and than wipe it off and check the seat area.
Dan
Dan
I like to use the fine first so that I am not cutting into something I dont need too. It is just a small extra step that helps insure a good job when done. Others like to just jump in head first and that might work for them but I was taught to take it slow and make sure it is done right.
