ITbs with s200 question
Old Feb 7, 2006 | 12:58 PM
spockeg's Avatar
Default ITbs with s200 question
ok my question is if anybody hear can tell me how to hack or make more columns on the fuel maps. cause my problem is during part throttle I'm sitting in column 5 & 6 and that is almost full throttle for me for my elevation. I know it can be done i just don't know how. so if anybody hear could help me out that would be great. thanks in advance, spock
Old Feb 7, 2006 | 02:16 PM
Chris22215's Avatar
Default Re: ITbs with s200 question (spockeg)
you can't do it. the itbs don't keep a stable vacuum for the map to read. At anything higher that about 25% you'll be reading in the last 3-4 columns. Just because they're is no way to hold vacuum. What you need is crome, it's some a setup where is picks the column based on map and tps. So you've got a wider range
Old Feb 12, 2006 | 06:04 PM
spockeg's Avatar
OK i messed with my laptop for a while and it is possible to change the millivolts on a s100/200 you cant add columns but if you are N/A you can stretch the vacuum in to the boost columns. there for not adding but adding columns. So you have more volts to work with and not such a big section.
Old Feb 13, 2006 | 04:09 AM
v4lu3s's Avatar
RTFM
its a pain but not impossible to do, i actually went ahead and rescaled the column headings for a car i am working on. never og it running right though since it spun a rod bearing at the same time.
youngboiCD7
Engine Management and Tuning
Apr 12, 2018 06:13 AM
j0keefe21
12
Jun 13, 2010 12:30 AM
chris3385
Jan 3, 2009 04:49 AM
cjames235
26
Aug 2, 2004 08:28 PM
Kataku2K3
Oct 21, 2002 02:11 PM
