HELP! What ecu do I need
Old Feb 9, 2006 | 02:37 PM
Didly's Avatar
Default HELP! What ecu do I need
I am currently installing 95 ZC with vtec... the guy said I need OBD1 but which ecu should I get? I was thinking the Pr2 or the PO8 because someone said my motor is a JDM d15b or somthing... any help will be greatly apreciated
thanks
Old Feb 9, 2006 | 07:53 PM
Didly's Avatar
bump
Old Feb 9, 2006 | 08:38 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (Didly dane)
p28
Old Feb 9, 2006 | 08:46 PM
Scorchin Civic's Avatar
If it does have the block code D15B then yes it's a 1.5 SOHC Vtec motor and you can use the P08 since it would be the right ecu for it. However, I think a P28 would work just as good too.
Old Feb 9, 2006 | 10:36 PM
Didly's Avatar
Nah it says ZC but it has vtec...
Old Feb 9, 2006 | 11:36 PM
Didly's Avatar
bump
Old Feb 10, 2006 | 08:59 AM
DYNO-PRO
ITS A ZC SOHC VTEC THEN ITS A 1.6 SO AGAIN P28 FOR SURE
Old Feb 10, 2006 | 08:14 PM
Didly's Avatar
cool... any p28 will work..? or does it need anything special or what?
Old Feb 12, 2006 | 12:00 PM
HandCommand's Avatar
Just make sure you get a P28 for a manual transmission otherwise you will get check engine light for Auto tranny shift solenoids.
Old Feb 12, 2006 | 05:20 PM
Didly's Avatar
Default Re: (HandCommand)
kk thx guys got one from my buddies hatch today.. doin swap this weel
Old Feb 13, 2006 | 10:16 AM
DYNO-PRO
showbowt
Mar 19, 2008 03:06 PM
B16_DC2
Jan 16, 2007 07:35 AM
Ohhenrygsr
Dec 20, 2005 11:45 PM
moflex
Feb 22, 2005 07:08 PM
EK_vzla
Feb 8, 2004 09:57 AM
