obd0 to obd2 injector
Old Feb 9, 2006 | 05:01 PM
shuttle xer's Avatar
Default obd0 to obd2 injector
i swapped a obd2b b20vtec into a 91 dx. Now it barely starts and does not hold idle. the **** misfires like a mother.
it has to be fuel or spark. i replaced the rotor, cap, wires, ignition coil and plugs. still no dice.
i noticed that on the injectors there is a (+) positive symbol on the side of it. The side with that symbol is where the ground wire goes (colored wires.blue,red,yellow,brown). is the power supposed to be running to those wires?
that might be one of the reasons why this thing doesnt really start.
Old Feb 9, 2006 | 05:07 PM
Runnerdown's Avatar
Default Re: obd0 to obd2 injector (shuttle xer)
Did you use the connectors from the obd2 harness. I never noticed any plusor minus signs. The yellow and black is 12v ignition switch on and each individual color wire is grounded by the ecu. You are not running a resistor box correct?
Old Feb 9, 2006 | 09:38 PM
Default Re: obd0 to obd2 injector (Runnerdown)
correct. i still cant find the reason for this misfire/no start problem
LuckyStrike90
Aug 2, 2024 12:10 AM
cslegacy
Feb 28, 2009 03:56 PM
IIXtremeHansen
Jan 14, 2008 05:00 PM
shuttle xer
Feb 14, 2006 11:14 PM
Frozen E
Oct 28, 2004 08:51 AM
