HELP!!! Main relay/fuel pump/ ignition switch???
Old Feb 5, 2006 | 03:07 PM
TURBO4drTypeR's Avatar
Default HELP!!! Main relay/fuel pump/ ignition switch???
HI!, i've searched and read for days now and still have no clue to whats wrong with my car... i have an integra that on obdII under the dash and obdI on engine harness...
sometime the car dies while im on the roll(any speed) i tried popping the clutch but it still wont start when it dies while rolling(if rpm is not above 3.5) it wont get going. sometimes it just dies out at idle and it'll start back up if started in the first few tries and i have to keep the rpms up past 4k...if not it stays dead untill everything is cold again...
the problem i have is soo inconsistant that i still cant figure out whats wrong with it. I have tried numerous different distributors so i know thats not the problem...
i've tried 3 different main relays and it still does the same thing. the only thing i haven't changed is the pump and ignition switch... the pump primes everytime though...(could it just be a bad pump?) maybe when the circiut gets hot the pump quits??? but if the pump is bad then i assume it will not prime, correct?
honda-tech has always come to my rescue in the past, so im hoping you guys can help me out again... its just one of those things that's kicking me bad
thanks for looking
Old Feb 5, 2006 | 05:25 PM
Default Re: HELP!!! Main relay/fuel pump/ ignition switch??? (TURBO4drTypeR)
anyone??? somebody???
Old Feb 5, 2006 | 05:34 PM
non-VTEC's Avatar
interesting that you had the same similar problems that my friends 98 civic went through.
we replace the ignitor and main relay but the problems still existed. we replace the ignition switch.....problem solved.
i would try a ignition switch......
Old Feb 6, 2006 | 08:52 AM
Default Re: HELP!!! Main relay/fuel pump/ ignition switch??? (non-VTEC)
thanks for your input!!! i guess i'll change out my ignition switch and see what'll happen then...
more help would be greatly appreciate
Old Feb 6, 2006 | 05:12 PM
86si's Avatar
not sure what year your teg is but the civic's had an ignition switch recall on 99-00. it is very common and is a free repair. The integra's proly share the same recall.
Old Feb 6, 2006 | 08:27 PM
Default Re: HELP!!! Main relay/fuel pump/ ignition switch??? (86si)
hmmm... interesting news
thanks again! i'll have to check that out. been busy so i still havent change my ignition switch yet... but i'll post up when i get the problem solved
Old Feb 7, 2006 | 01:22 PM
what were the exact symtoms you guys had with the bad ignition switch???
my motor turns over, has good spark, i can definately hear the pump whining, but i wont start!!! could the pump not be pumpin enough fuel or how does a bad ignition switch cause so much trouble???
Old Feb 7, 2006 | 02:57 PM
non-VTEC's Avatar
my friends civic had a stalling problem after driving a while......once it stalled it would not re-start for about 10-15min.
while it would not start there was no power at the fuel pump, no spark, no injector pulse and no power to the ECU.
we checked/replaced the ignitor and main relay but the problem was still there.......once we replace the ignition switch the problem went away...
Old Feb 8, 2006 | 07:22 PM
PTL's Avatar
PTL
my brother's prelude had the same problems like that before all the light in the dash and everything were off . It wont start either , we took it to honda dealer they found and fix the problem it was a ignition switch
it me Philip
Old Feb 8, 2006 | 08:53 PM
WhiteNess's Avatar
Default Re: (PTL)
Check all your grounds....especially the one on the thermostate housing.....forgot to tighten it one time on a swap and had some similar problems.
Old Feb 9, 2006 | 07:55 PM
Default Re: (WhiteNess)
my car was running fine for some time now... it just decided to act up a month ago and just recently crapped out... i double checked almost everything i could and i still have no clue whats wrong... i know for SURE its NOT my ignition switch, distributors and main relay nor my grounds... i still havent change the pump yet... well on my way home from work i thought of the resistor box? could that be an issue??? i know my injectors work cause i took the distributor out and turned it to check that... im so frustrated cause my car has been down for a while now and its my only car... can someone or anyone possibly have any other clues or ideas??? please help me out
thanks
Old Feb 9, 2006 | 08:33 PM
MaxBoostC1's Avatar
Default Re: (TURBO4drTypeR)
check the 3bar map sensor plug....
Old Feb 9, 2006 | 09:41 PM
Default Re: (MaxBoostC1)
thank you sir for your input how'd you know i have a 3 bar??? i do have one and i sure will check it anyways... so thanks to all that has given me a legitimate answer!!!
more ideas please...
Old Feb 10, 2006 | 07:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoostC1 &raquo;</TD></TR><TR><TD CLASS="quote">check the 3bar map sensor plug....</TD></TR></TABLE>
well i put in a new 3bar map and let it idle for like 30 minutes and it ran fine... i did this in the cold after i got off of work so i'll have to wait till morning and try it again and see if the problem is solved... then i also plugged in my old 3bar and it idled for a good 15 minutes... i went ahead and turned it off because its freezing outside so i'll have to check everything again in the morning...
i hope the problem is fixed for good... thanks alot for your help and check your IM...
Old Feb 11, 2006 | 05:32 PM
well it turned out not to be my 3bar map... i went back and diagnosed everything again and came to a conclusion that my resistor box might be bad... i have spark, my pump works fine, but i didnt see the top of my piston get soaked of fuel so the only thing left to crap out is the resistor box...( i know my injectors work)
Old Feb 11, 2006 | 05:42 PM
W C L's Avatar
- check all ur grounds, make sure there is no corrision on ur battery terminals....i have seen to many cars with corrosion and wonder y this and this doenst work.....
- ur power wires that feed the fuse box... i have seen them wiggle themselves loose and lose contact causing the car to die.....
- chipped ecu? bad ecu? bad chip
- sounds like wiring prob, check wiring at ur dist plugs......
keep me posted let me know what u find
Old Feb 11, 2006 | 09:46 PM
Default Re: (WCL Motorwerks)
im way ahead of you on all that... but thanks for you input... i will change out my resistor box tomorrow.
i will keep ypu guys updated
thanks
Old Feb 15, 2006 | 12:25 AM
It was my dang resistor box!!!!!!!
THanks to all that tried to help me out...
Old Apr 13, 2006 | 11:07 PM
the.hamburglar's Avatar
what was wrong with your resistor box? im having the same problems
Old Apr 18, 2006 | 08:12 AM
Maxime's Avatar
I'm having somewhat of a similar problem.
It started a couple of days ago.
After driving around for a while I would hear a clicking noise coming from under the dash on the passanger side. The car would "die" when it clicks and come right back to life in a split second.
I removed the glove box and im 100% positive that it's the main relay making the clicking noise. So I bought a new one a replaced it.... that didnt solve the problem.
What could cause the main relay to click like that?
Maxime,
Old Apr 18, 2006 | 08:49 PM
Maxime's Avatar
need help ttt
wwolf771177
Mar 25, 2013 02:54 PM
acidburn2k2
Dec 10, 2009 06:25 AM
crazyimport
Sep 2, 2008 09:22 AM
Project T
Jan 28, 2007 05:02 PM
2camsaam
Jul 14, 2003 09:09 AM
