Need Help ASAP
Old Feb 11, 2006 | 10:08 AM
Dinero's Avatar
Default Need Help ASAP
wuts good i got a problem dont kno wut tha expletive is goin on i got a 90 integ wit a 93 ls motor that i jus swapped in car started up and rans no problem beside a sensor problem that i have on the throttle body thats causes tha motor 2 idle high and hold.The real problem that i have thats rackin my brain is when i put antifreeze in tha radiator the motor starts smokin like a bitch please help needed asap
Old Feb 11, 2006 | 10:17 AM
vtecman69's Avatar
Default Re: Need Help ASAP (Dinero)
yo what i have bad news fo u sounds like blown head gasket the code is cuz no anti frezze thats y its idleing high im mechanic
Old Feb 11, 2006 | 10:23 AM
Dinero's Avatar
Default Re: Need Help ASAP (vtecman69)
it only smokes tho when i fill tha radiator up and if it was a blown head gasket wouldnt the oil and antifreeze mix and make it like a coffee color milkshake
Old Feb 11, 2006 | 11:33 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dinero &raquo;</TD></TR><TR><TD CLASS="quote">it only smokes tho when i fill tha radiator up and if it was a blown head gasket wouldnt the oil and antifreeze mix and make it like a coffee color milkshake</TD></TR></TABLE>
Not if the coolant is leaking directly into the cylinder. I suggest a simple compression check to test for a leak.
sixyearhome
May 27, 2013 06:37 PM
VTECwalka
Oct 30, 2012 06:02 AM
dohclsv
13
Mar 12, 2008 06:10 PM
ObeyDB8
Mar 22, 2007 08:39 AM
ECKOTYPER
Jan 30, 2004 04:22 PM
