Peak and hold or saturated Injectors?
Old Feb 9, 2006 | 09:38 AM
f1 vtec's Avatar
Default Peak and hold or saturated Injectors?
Hi can someone please explain the difference between peak & hold and saturated injectors. what they mean and how they work etc. I tried searching but got no real answer!
Your help would be appreciated
Old Feb 9, 2006 | 10:14 AM
b18bturbo's Avatar
Default Re: Peak and hold or saturated Injectors? (f1 vtec)
injector is just a coil driven device.
The injector works based either on low ohm driver or high ohm driver.
The difference between the two is that peak and hold is driven by 2ohm-3ohm driver while saturated needs 12-16ohm to fire.
the early gen integras,civics,and accords had resistor boxes that would allow you to run a peak and hold injector the newer cars all primairly use a saturated drive.
AEM sells a device as well as FJO electronics that can be used to drive any injector
Old Feb 10, 2006 | 10:08 AM
f1 vtec's Avatar
Default Re: Peak and hold or saturated Injectors? (b18bturbo)
thx
so what injectors should i get for my b18c obd1 running a p30. i want to avoid messing with a resistor box
Old Feb 10, 2006 | 10:43 AM
drdisco69's Avatar
OBD0 runs peak-hold with a resistor box, OBD1 and 2 use saturated.
Old Feb 13, 2006 | 05:00 AM
f1 vtec's Avatar
Default Re: Peak and hold or saturated Injectors? (drdisco69)
so if i wanted to use 850ccs on my 0bd1 would i need a resistor box or not?
Old Feb 13, 2006 | 06:14 AM
drdisco69's Avatar
If they are peak-hold injectors, yes. If they are saturated injectors no.
Old Feb 13, 2006 | 11:10 AM
f1 vtec's Avatar
Is there such things as saturated 850cc injectors for the obd1 because i find alot of ppl seem to use resistor boxes on their turbo obd1's?
Old Feb 13, 2006 | 11:41 AM
b18bturbo's Avatar
the highest you will find in saturated usually in the united states is 780cc from RC
they are very costly wise in the 350.00 price range when a comparable set of low imp peak and hold is 285.00 or so
Old Feb 15, 2006 | 11:26 AM
f1 vtec's Avatar
should the saturated 780cc's b good for approx 450 hp?
Old Feb 15, 2006 | 11:33 AM
b18bturbo's Avatar
they would be perect anything under 500hp
Old Feb 15, 2006 | 10:18 PM
f1 vtec's Avatar
thx your help is appreciated
Old Feb 16, 2006 | 06:44 AM
EE_Chris's Avatar
If an engine was tuned on saturated injectors and then switched over to a p/h injector of the same rating, will a re-tune need to be performed or will the car behave exactly as it did prior?
Old Feb 16, 2006 | 07:57 AM
b18bturbo's Avatar
Default Re: Peak and hold or saturated Injectors? (EE_Chris)
it should be identical performance as long as you switch in the same amount of flow for that injector. Everyinjector with time however becomes clogged and cant flow as much as the day it was new.Therefore some fine tuning might be required but overall you should be fine just swapping in the same size.
Evansouders
Jul 30, 2013 05:50 PM
GT500FTW
Nov 29, 2012 03:10 PM
lowtegsr
Jan 14, 2008 01:25 PM
Muckman
May 14, 2006 01:31 AM
drSquish
Jan 19, 2006 01:54 PM
