EG B16 Swap problems
Old Feb 5, 2006 | 12:38 PM
theneil's Avatar
Default EG B16 Swap problems
I have a 92 CX hatch with a JDM B16A2 swap
Compression is good, grounds are good, fuses are good, dizzy is good, timing and valves have been properly adjusted
CX harness is a mess- I'm stuggling with the electrical! Could someone please point me in the right direction for the CX to OBD-1 info I would need to wire this thing up properly. I have done some research already, but for every piece of info that I find that seems to help I find something that contradicts it
or
I have just been thinking about buying a 92-95 Ex/Si wire harness to make my life a whole lot easier. Does anyone know a reliable shop I could order one from? I'm leaning more towards just buying one to keep the eng bay clean
thanks for the help
Old Feb 5, 2006 | 01:05 PM
tallyturbo's Avatar
Default Re: EG B16 Swap problems (theneil)
you only have to add a few wires to the existing harness i believe. when i did my swap i had to add wires for vtec silinoid, vtec oil pressure, and i didnt do one for the knock sensor because im using a chipped ecu and we just turned the knock sensor off that way. you have to add wires all the way back to the ecu though.
Old Feb 5, 2006 | 01:45 PM
Pojazz's Avatar
i did a b16b eg swap and used an 99 ex harness
Old Feb 5, 2006 | 06:25 PM
theneil's Avatar
Bump
Etzim
Jan 3, 2012 10:23 PM
dkboyny11
Apr 15, 2007 11:21 AM
94si94cx
Nov 26, 2002 11:18 AM
Lysawy
Oct 20, 2002 10:52 PM
