Piston ring end gap question (My ring end gap varies)
Old Feb 4, 2006 | 07:09 PM
KooK's Avatar
Mustang Sally
Default Piston ring end gap question (My ring end gap varies)
My top ring end gaps vary from .017-.018
My middle ring end gaps vary from .019-.022
I'm wondering if this is ok or not? Also, one of them isn't a perfect sqaure but it's close (this is on my loosest ring or else I would fix it). Should I be ok? These are Wiseco Pistons with a 81.5mm bore on a B18C1
Thanks!
Old Feb 4, 2006 | 07:26 PM
uplink's Avatar
Default Re: Piston ring end gap question (KooK)
drive it, make sure the gap from primary to secondary are 90 degress spaced. with primary fackin 12 o clockerz
Old Feb 4, 2006 | 09:08 PM
EnzoSpeed's Avatar
I'm not sure why the gaps vary, but it's not a problem. Just match the rings with the right cylinders. In other words, the largest gapped rings should go in cylinder #3, the second largest should go in cylinder #2, and the two smallest sets should go in cylinders #1 and #4. This keeps the loosest gaps in the hottest cylinders.
Don't bother squaring up the one ring. It will only create more blowby.
Spoon84
Jul 19, 2010 09:22 PM
Spoon84
Jul 19, 2010 01:34 PM
KURUPTinc
Aug 25, 2007 12:24 PM
gramentz
Jun 5, 2005 08:07 AM
Thats-so-Ls
Dec 29, 2001 07:17 AM
