how to clean headlights?
Old Feb 6, 2006 | 08:10 PM
92eg6_pino's Avatar
Default how to clean headlights?
i just wanna know how do you guys take out that crusty yellow look on a stock 96-99 civic headlights. thanks...
Old Feb 6, 2006 | 09:24 PM
old man neri's Avatar
Default Re: how to clean headlights? (92eg6_pino)
If it's on the outside (usually is) you can polish it off (search there are some right ups) or you can buy a speacial product (available most places) that is exactly meant for this. I would just buy the product.
Here are a couple of threads talking about this. I am not going to search further, I will leave that to you.
https://honda-tech.com/zerothread?id=938083
https://honda-tech.com/zerothread?id=1460615
Cheers.
Old Feb 6, 2006 | 11:47 PM
mastarolla's Avatar
meguiars plastix is the name or close to it. Apply several times and buff it into the plastic kinda fast...you would be amazed at the clarity afterwards
Old Mar 2, 2006 | 01:11 AM
cilvia's Avatar
Default Re: how to clean headlights? (mastarolla)
where can i get these plastic cleaners/polish?? i been looking and cant find
Old Mar 2, 2006 | 06:04 PM
Default Re: how to clean headlights? (cilvia)
I don't know about the states but in Canada it would be at "Canadian Tire". I think the American equivelant is a place called "pep boys"
http://www.meguiars.com/dealerlocator/
(find a dealer)
and
http://www.meguiars.com/?clear...olish
(order online)
Hope it helps,
Cheers.
Also, thanks for using search!
Old Mar 5, 2006 | 04:13 PM
cilvia's Avatar
Default Re: how to clean headlights? (old man neri)
I NEED HELP.....ok i wet sanded the headlights wit 1000 grid first then wit 2000 after...i then used meguairs plastix to clean and polish it out...but it really doesnt look as good as i thought it would be...it actually looks blurry-er now than clearer cause you could see the scratches from the sand paper still...i buffed the crap out of it too...what can i do to make it shine and clear up??
Old Mar 6, 2006 | 12:26 AM
cilvia's Avatar
bump
Old Jul 25, 2006 | 05:33 PM
civicstar's Avatar
on the outside, you just take rubbing compound (heavy duty kind or turtle wax rubbing compound will work) and put it on there and take a buffer to it and it should come right off and then use polishing compound after that
soofly
Honda Civic (2001 - 2005)
Feb 26, 2009 07:11 AM
Domexxx
Lighting
May 21, 2008 12:33 PM
Honda_Driver
Nov 21, 2004 12:05 AM
Civic4less
15
Nov 7, 2004 02:13 PM
wall of tvs
Aug 9, 2002 01:48 PM
