CEL 22 vtec??
Old Feb 3, 2006 | 09:50 AM
Boosthead's Avatar
Default CEL 22 vtec??
I just received a CEL while driving my car. I pulled the code and it was 22, VTEC. The VTEC Solenoid was replaced 6mos to a yr ago. I called a local shop and they didnt have any ideas. Also, I looked in a chiltons manual and couldnt find any suggestions either.
Can anyone point me in the right direction?
The car is a 92 civic with a JRSC @9lbs. It's using the JR FMU, no hondata, etc.
Old Feb 3, 2006 | 12:51 PM
JimBlake's Avatar
Default Re: CEL 22 vtec?? (Boosthead)
I think 22 is the VTEC oil pressure switch. The VTEC solenoid would have been code 21.
Old Feb 4, 2006 | 10:33 AM
ViXoN Hatch94's Avatar
Default Re: CEL 22 vtec?? (JimBlake)
try changing the green switch on the solenoid... also check your oil pressure. check your wiring at the ecu and make sure the switch is still grounded.
Old Feb 4, 2006 | 03:45 PM
Tad's Avatar
Tad
Default Re: CEL 22 vtec?? (ViXoN Hatch94)
examine the wiring running to the solenoid and switch..
most likely theres a problem there somewhere.
or yeah it could be the switch itself..
vtec solenoids arent that expensive anyways, if you have to you can just get a used one(with switch built in).
also i'd highly recommend the JR map mod to go with ur setup
Old Feb 4, 2006 | 07:51 PM
uplink's Avatar
honda sells the switch and pressure sensor in its housing complete with rubbers, that will fix u up. do it.
cioli
12
Feb 26, 2006 08:31 AM
jbscivichb92
Aug 16, 2004 05:13 AM
tegon-gsr
Nov 5, 2003 08:16 PM
Soled Out
Feb 11, 2003 08:10 AM
shonnys92si
Jan 20, 2003 11:45 PM
