catch can q's lsvtec b18b1
Old Feb 10, 2006 | 07:37 PM
912's Avatar
912
Default catch can q's lsvtec b18b1
searched post on catch cans, i'm confused a bit when i run line from pcv to catch can do i eliminate the pcv valve or do i simply clamp hose on pcv then run to catch can, see i did lsvtec with b18b1 block with gsr head pcv vave just dangaling no where to put it
Old Feb 10, 2006 | 08:59 PM
912's Avatar
912
Default Re: catch can q's lsvtec b18b1 (912)
*** nobody no's
Old Feb 11, 2006 | 04:09 AM
NJIN BUILDR's Avatar
If the pcv valve is not connected to the intake (under vacuum) it will not work properly.You must eliminate the pcv valve if your using a catch can that is not connected to the intake.
Glenn
Old Feb 11, 2006 | 02:15 PM
912's Avatar
912
Default Re: catch can q's lsvtec b18b1 (NJIN BUILDR)
great thanks
gsr dood
Mar 20, 2006 07:24 PM
912
Feb 11, 2006 07:34 PM
eluder33
Mar 24, 2005 11:19 AM
