STALE CEL (Check Engine Light)
Old Feb 3, 2006 | 03:50 PM
TeH PLAYA's Avatar
Default STALE CEL (Check Engine Light)
well guys basically I have a stale CEL. I'm running a JRSC with Hondata s200 and p28 ecu and the car is an EM1.
Prior to the stale CEL I had a true CEL which was a code 43 (fuel supply), so I replaced my o2 sensor and reset the battery. Now the CEL is on but there is no code, and the CEL is only on after I start the car (it is not on when the key is on the number 2 position).
When I short the service connector with the key on the number 2 position, the CEL turns on, but does not flash, and turns off again once I remove the paperclip from the service connector.
I've heard that it can be a bad ECU. Should I swap it with my stock P2T real quick? I'm running 440cc injectors. If I swap ECU's (P2T or any stock OBD1 ECU), will the motor run pig rich because the ECU is not calibrated to operate with 440cc injectors?
I opened up my ECU and it looks like new. The Hondata shows a solid red light when I took it all apart, so I think that is still good.
Any ideas or suggestions?
Old Feb 3, 2006 | 04:33 PM
BB6racer's Avatar
the CEL will show up, and not throw a code, if your gas cap is not screwed on all the way or if it doesn't seal all the way. try that.
92DAB16A
Sep 14, 2012 07:14 PM
justseeingifitistaken
Nov 22, 2006 06:21 PM
TeH PLAYA
Feb 8, 2006 01:03 PM
crvtt96
Jun 6, 2004 04:00 PM
denshu
Dec 16, 2003 02:48 PM
