Ridge formation at the top of the cylinder
Old Feb 7, 2006 | 04:30 PM
THE GAME IS THICK's Avatar
Default Ridge formation at the top of the cylinder
Since im pretty much a engine rebuild newbie I have a question about the ridge formation at the top of the cylinder wall. I am getting some head work done and it is currently at the machine shop getting pressure checked, new valve seals, 3 angle valve job, and blah blah blah. But my qustion is would it be ok if I slapped on the head on my existing block even if there is a ridge formed at the top of the cylinders? I am not taking out the pistons out or doing anything to the block. I understand that if i remove that ridge it may be possible that i wont get a correct seal with my existing piston rings in there.
BTW: Its a B18C1 and has 75k on the block. I will post pictures when I get a chance to take them.
Old Feb 7, 2006 | 05:54 PM
non-VTEC's Avatar
Default Re: Ridge formation at the top of the cylinder (THE GAME IS THICK)
you can leave it......nothing bad will happen if you leave it or remove it but you need to be careful when cleaning the ridge of carbon that you don't damage the cylinder walls.
i would just leave it.....you wont gain anything by removing it.
Old Feb 7, 2006 | 07:47 PM
Default Re: Ridge formation at the top of the cylinder (non-VTEC)
thanks non-VTEC. im gonna just slap the head back on then.
anyone else want to put their $0.02 in?
Old Feb 8, 2006 | 09:49 AM
dognutz's Avatar
I rebuilt an engine and left the ridge and everything was fine. As long as you don't change anything to make the piston reach higher in the chamber than the piston that made the ridge. This would damage the rings quickly.
Old Feb 8, 2006 | 03:05 PM
BigMoose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GAME IS THICK &raquo;</TD></TR><TR><TD CLASS="quote">I am not taking out the pistons out or doing anything to the block. </TD></TR></TABLE>
Given the above statement, you cannot remove the ridge, nor would you want to. Anything you would do would not increase performance (as the upper ring stops below the ridge) and would only contaminate the bore with either metal chards, or carbide grit. All bad for the life of the existing ring/cylinder.
If you have a dial bore gauge it would be interersting to see how much the bore wore, and how many miles are on the block.
If you are working the head alone, let the bores be. You will be OK. Good luck with your rebuild.
Old Feb 8, 2006 | 03:13 PM
Default Re: Ridge formation at the top of the cylinder (BigMoose)
you guys helped me with my decision.
thanx bigmoose, dognutz, and non-VTEC again....
now i just need to find a transmission locally.
jiggacivic
Aug 11, 2011 09:35 PM
tmrtwo
Mar 25, 2007 11:53 AM
B-B-K
Aug 9, 2005 09:01 PM
JohnnyEF
May 29, 2003 12:38 PM
JohnnyEF
May 28, 2003 02:54 PM
