LSD Question
Old Feb 7, 2006 | 10:06 PM
lodo1's Avatar
Default LSD Question
hey guys, i'm lookin at buyin this b16 tranny from a buddy of mine, and its got a weird tranny setup. ok, you know on the tranny, the axel goes in on both sides. well, on this tranny, on the driver side, the axel goes in, but on the pass side, there is like an axel tip on it. it has all the axels and half shaft, but i was just curious on what the heck it is. pretty much both axels are the same with the female ends on the axels, and male ends on the tranny and halfshaft.
anyone know if its a lsd, and what kind it is?
Old Feb 8, 2006 | 01:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: LSD Question (tdocrx)
Is it a cable transmission or hydro? Got pics?
LSD transmission you can see through the axle holes. Non-LSD you can't.
Old Feb 8, 2006 | 05:16 AM
lodo1's Avatar
Default Re: LSD Question (JDM_Ej)
yea, i will get pics tonight. its a hydro tranny.
Old Feb 9, 2006 | 06:38 PM
lodo1's Avatar
Old Feb 9, 2006 | 09:26 PM
lodo's Avatar
thats just screwy. bump for an answer
Old Feb 9, 2006 | 10:31 PM
ozzyman's Avatar
Default Re: LSD Question (lodo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lodo &raquo;</TD></TR><TR><TD CLASS="quote">thats just screwy. bump for an answer</TD></TR></TABLE>
Seriously... I'm curious now.
Old Feb 10, 2006 | 11:51 AM
JDMCivicEF9's Avatar
Default Re: LSD Question (ozzyman)
I never seen anything like that. Somebody must of been experimenting with it doing some sort of axle combo or setup.
Old Feb 10, 2006 | 12:06 PM
shorto85's Avatar
Well that tranny is a LSD tranny no question about that. Im curious about the shaft that is sticking out though!
Can you count the splines for us? That may help clue us in on what it is. Can that shaft be removed?
Old Feb 10, 2006 | 07:11 PM
ralphie14's Avatar
Default Re: (shorto85)
Bump for a buddie, and an answer
Old Feb 14, 2006 | 03:48 PM
lodo1's Avatar
Default Re: (ralphie14)
anyone?
Old Feb 14, 2006 | 08:42 PM
fastrunner's Avatar
Default Re: (tdocrx)
anybody hear think an axle shaft was cut to make a spool out of that LSD. Seems like a pretty good way to make f-ed up differential work. the splined shaft sticking out looks exactly like an axle. I've never seen aftermarket axles with a female end on the tranny side at least not for B series???
Bump for an answer and comments.
Old Feb 27, 2006 | 08:16 AM
lodo1's Avatar
Default Re: (fastrunner)
bump for some thoughts on what it could be
Old Feb 27, 2006 | 11:10 AM
drumking15's Avatar
my edumacated guess would be....he installed a obx gen 1 lsd....knew the axle wasnt going to come out....so took the male end of an axle....and made himself a custom set that can be taken off...only prob i see....is how the axle is actaully held onto the stub
another problem i forsee...is how well that axle seal is going to seal...i can see lots of tranny fluid being lost
Old Feb 27, 2006 | 06:00 PM
lodo1's Avatar
Default Re: (drumking15)
thats a pretty good theory. any way i can find out if its correct?
Old Feb 27, 2006 | 06:12 PM
drumking15's Avatar
only way to confirm it would be to ask wtf he did it....id stay stear clear regardless of what it has....maybe he set it up to run 2 half axles like that off the half-shaft....so he'd only have to bring 1 thing instead of 2 and kills hte problem w/ the obx lsd...wow now that be crazy...still have a hard time understanding of how it make a good oil seal tho
Old Mar 5, 2006 | 01:10 AM
lodo1's Avatar
the axel actually tucks in pretty good from the test fitment i did on it.
taffywhtb16
14
Mar 24, 2010 10:13 AM
iwantspeed
Apr 20, 2007 07:24 PM
si90rex
May 19, 2006 11:21 AM
spooned out
Aug 24, 2003 10:15 PM
