oil smells like fuel
Old Feb 5, 2006 | 12:23 PM
1991civicsi's Avatar
Default oil smells like fuel
D16A6 fresh rebuild with 2k miles on it. Im using full synthetic and after second oil change upon inspection my oil smells like fuel. Is this normal?
Old Feb 5, 2006 | 09:54 PM
Takumi Fujiwara's Avatar
Default Re: oil smells like fuel (1991civicsi)
Are you losing any oil?
Old Feb 6, 2006 | 12:28 AM
ED7's Avatar
ED7
Well some fuel will get by, so it will smell like fuel. So were the clearances on the rings all in spec? If compression is fine and you know you built it well, you should be fine. Check your pcv system and make sure its working properly. So is it running ok, not too rich? Did you use non synthetic at first? Because the rings may have not seated as well as they should have if you used synthetic. If excess fuel is entering the oil, then synthetic will not break down like conventional oil, so thats good.
Old Feb 6, 2006 | 04:04 PM
Default Re: oil smells like fuel (ED7)
My car burns oil due to worn valve guides. I broke it in with conventional. Yes she is running rich, T3 setup in process, so PCV system will be upgraded (breather filter, maybe catch can) and my ECU will be re programmed. I will continue to run synthetic to protect her furthermore. Thanks
zach53
Feb 28, 2012 03:05 PM
skate1968
Jun 26, 2007 07:22 AM
SRd240sx
Dec 25, 2005 03:08 PM
one8toh8
Feb 4, 2005 11:06 AM
crash
Jul 17, 2002 07:55 AM
