Need help identifying these pistons!!
Old Feb 8, 2006 | 07:18 PM
TheBetterSol's Avatar
Default Need help identifying these pistons!!
I recently bought a 84mm b18 block and it came with rods and pistons, nothing was put togeather it was all loose, well the guy who sold it to me said that the pistons were for all-motor, high comp. well i dont know much about pistons so i asked him, and he asured me that they were high comp all motor pistons. let me know what you think, here are some pix i took.
Modified by 1badeg6 at 4:28 AM 2/9/2006
Modified by 1badeg6 at 4:31 AM 2/9/2006
Modified by 1badeg6 at 4:32 AM 2/9/2006
Old Feb 8, 2006 | 07:36 PM
Default Re: Need help identifying these pistons!! (1badeg6)
there is also a name printed on the block, he told me he bought it off of a fellow HT member who is known for building blocks it says "ELLIS" "NV 3"
maybe someone knows who he is??
Old Feb 8, 2006 | 08:22 PM
i know there has got to be someone out there in honda-tech land that can help me out
Old Feb 8, 2006 | 08:27 PM
EnzoSpeed's Avatar
Wait, so what do you need to know? They're 84mm high comp JE pistons. Do you want to know the exact compression? You can tell by looking at them that they're high comp (i.e. raised dish area).
Old Feb 8, 2006 | 08:32 PM
Default Re: Need help identifying these pistons!! (EnzoSpeed)
i all ways thought that all high comp pistons basically looked the same, you know the raised dome, and it would be nice to know that exact compression of them.
Old Feb 8, 2006 | 09:02 PM
Ruben19's Avatar
they look low compression to me!!
i would say around 9.5 to 10
they have a flat top
Old Feb 8, 2006 | 09:59 PM
gsrious's Avatar
Default Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">they look low compression to me!!
they have a flat top</TD></TR></TABLE>you are freaken blind. don't give out false info.
Old Feb 9, 2006 | 12:29 AM
Flashmn's Avatar
9 to 10.5 isnt low compression, thats high compression.
Low compression would be from 6-8.5 or so.
Old Feb 9, 2006 | 12:50 AM
EnzoSpeed's Avatar
Default Re: (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">9 to 10.5 isnt low compression, thats high compression.
Low compression would be from 6-8.5 or so.</TD></TR></TABLE>
Not on a Honda it ain't. Low compression is almost universally 8.5 - 9. Most people don't go as low as 8 and 9.5 is kind of high for decent boost levels.
Seeing as the motor is a B18 (I'm assuming it's a C1), JE considers high compression for that motor to be between 11.5:1 and 12.4:1.
Old Feb 9, 2006 | 12:54 AM
EnzoSpeed's Avatar
Default Re: (EnzoSpeed)
Call JE and give them that number that's stamped on the underside. I've done that before. They can identify the pistons for you.
Old Feb 9, 2006 | 03:06 AM
non-VTEC's Avatar
they look like low compession pistons to me.......probably aound 9:1 since JE only sells them off the shelf in 9:1, 10.5:1, 11.5:1 and 12.5:1 without going to custom orders.
Old Feb 9, 2006 | 11:31 AM
d16dcoe45's Avatar
Default Re: Need help identifying these pistons!! (non-VTEC)
Those are dished pistons, they are not high-compression all-motor pistons. You can see the raised quench area on the edge of the piston crown--and you can see the "dish" in the center. Probably around 9-9.5:1. It appears they would give even less compression than a flat top piston.
Old Feb 9, 2006 | 12:44 PM
EnzoSpeed's Avatar
Default Re: Need help identifying these pistons!! (d16dcoe45)
Do you have more pics? It's kind of hard to tell - I just looked at the first pic and it looks like a flat top. But in the second pic, they look dished...
Old Feb 9, 2006 | 01:11 PM
100K Sol's Avatar
Um, the engine code is stamped right in that picture (B18B1) so you don't have to assume it's a C1 cause it's not.
yes they are dished shaped, every one is telling me different things.
Old Feb 9, 2006 | 01:28 PM
Modified by 1badeg6 at 10:51 PM 2/9/2006
Old Feb 9, 2006 | 01:43 PM
100K Sol's Avatar
those don't look THAT raised. Sorry, but can you take a pic DIRECTLY from the side so we can see how much, if any, the center is raised?
Old Feb 9, 2006 | 01:45 PM
biotech0123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Call JE and give them that number that's stamped on the underside. I've done that before. They can identify the pistons for you.</TD></TR></TABLE>
Gets my vote, takes the mystery out of the question.
Old Feb 9, 2006 | 01:52 PM
Default Re: Need help identifying these pistons!! (biotech0123)
not raised at all, its more of like a dish
Old Feb 9, 2006 | 01:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biotech0123 &raquo;</TD></TR><TR><TD CLASS="quote">
Gets my vote, takes the mystery out of the question.</TD></TR></TABLE>
i called them and gave them the number on the bottem and he couldnt tell me much about them, but them i told him that they were disched shaped, then he told me right away they were low comp. pistons!! that son of a bitch ripped me off!!
Modified by 1badeg6 at 11:13 PM 2/9/2006
Old Feb 9, 2006 | 03:53 PM
ekek888's Avatar
they re for FI application. lowers compression from stock.
Old Feb 9, 2006 | 05:51 PM
Default Re: Need help identifying these pistons!! (ekek888)
Heres a glimpse at my high comp pistons
Old Feb 11, 2006 | 12:10 PM
thanx for all the help.
GT500FTW
Engine Machining & Assembly
Jun 14, 2015 10:52 AM
JDMCIVIC919
Feb 9, 2012 06:45 PM
nu2teg
Oct 26, 2010 09:03 AM
tuan_turbo_dc4
May 29, 2004 08:52 PM
