Need Odyssey help
Old Feb 4, 2006 | 09:30 AM
4gzchatch's Avatar
Default Need Odyssey help
Hey all, I need to know what all goes into the 37,000 mile service for a 2004 Honda Odyssey... anybody here work at a Honda dealership and care to tell me? Thanks!!!
Old Feb 4, 2006 | 10:34 AM
IN VTEC's Avatar
Default Re: Need Odyssey help (4gzchatch)
It'd be a 30k service. Since everything in the 7500 mile service is already included in your 30k, you won't have another service until you hit 45k miles (first coolant change).
I think it's:
Oil Change
Tire Pressures
General Inspection
^----------3.75k
Brake Inspection & Caliper Pin Lube
Fuel Injector Cleaner
Lubricate Hinges, Latches (like anybody ever does that on a regular basis unless it sqeaks)
^-----------7.5k + All the above
Tire Rotation
Alignment
I think there's more than just adding on a tire rotation and alignment to the 15k service. I have a brochure at work that I can look at.
^-----------15k + All the above
Valve Adjustment
Tune-up (depending on model and engine)
Transmission Fluid Change
Rear Differential Fluid Change (on AWD & RWD models)
Replace Air Filter
^-----------30k + all the above
I've only done oil change and 7.5k services. Everything above that is harder for me to remember.
Old Feb 4, 2006 | 07:27 PM
4gzchatch's Avatar
cool, thanks a ton. do you work for Honda? I called the service dept. today and they told me that I had missed the 30,000 mile service and was already due up for the 37,000 mile one, which was about when the service light came on... does that make sense?
I usually do all of my own service/maintenance, but maybe I'll take it in for the valve adjustment. I just changed the oil, I have a new K&N air filter and cabin filter on the way, rotated the tires, put in fuel injector cleaner about 5K miles ago, and bought me some tranny fluid to change that out... Any idea how much they'll charge me for just the valve adjustment? Thanks again!
Old Feb 4, 2006 | 07:46 PM
uplink's Avatar
Default Re: (4gzchatch)
30 something. is coolant check, tire rotation, air filters, inspection of all components and tightening of subframe.
Old Feb 4, 2006 | 07:47 PM
uplink's Avatar
Default Re: (uplink)
i think from experience valve is every 25k.
dpkelly
Honda Civic (2006 - 2015)
Mar 31, 2014 03:36 AM
nukem384
Mar 16, 2010 07:20 AM
hometheaterman
Jan 30, 2008 03:44 PM
Jaypee
22
May 26, 2004 10:14 AM
acatak
Jul 16, 2002 06:18 AM
