Cx wire harness does not plug into o2 senor?
Old Feb 10, 2006 | 01:14 PM
vxcivic's Avatar
Default Cx wire harness does not plug into o2 senor?
i need help, i have a d16y8 with cx wiring harness, but it doesn't plug and play into the o2 senor wire?? one plug have 4 wires, there other have 5.I heard taht there a way that you can splice and connect the two, but now sure how. Have someone had this trouble? can this be done? and if so how.. need all the help i can get.
thx
Old Feb 10, 2006 | 04:11 PM
suckawillis's Avatar
Default Re: Cx wire harness does not plug into o2 senor? (vxcivic)
your car is a vx, thats why. It had a 5 wire o2. Use the search function to find how-to's for wiring. What ecu? VX you need to keep the 5 wire, but a p28 just get a 4 wire.
Old Feb 10, 2006 | 05:17 PM
dfoxengr's Avatar
cx has 1 wire...
Old Feb 10, 2006 | 06:31 PM
vxcivic's Avatar
its a vx, and a p28 ecu,so how do i wire it so the o2 senor work, and the check engine turn off???
Old Feb 15, 2006 | 03:42 PM
vtecnologist's Avatar
you need a 5 wire o2 sensor
its about 500 bucks
im having the same problem with my vx right now
i need an o2 sensor and i dont want to spend that much money
if you figure it uot let me know....
Old Feb 16, 2006 | 07:08 AM
EE_Chris's Avatar
Default Re: Cx wire harness does not plug into o2 senor? (vtecnologist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecnologist &raquo;</TD></TR><TR><TD CLASS="quote">you need a 5 wire o2 sensor</TD></TR></TABLE>
No, he doesn't. He's running a P28 which looks for and uses a 4-wire variety.
Old Feb 16, 2006 | 11:35 AM
JDMCivicEF9's Avatar
Default Re: Cx wire harness does not plug into o2 senor? (EE_Chris)
These links should help
https://honda-tech.com/zerothread?id=1513794
https://honda-tech.com/zerothread?id=1180819
http://www.hybridautomotive.com/tech/o2/#seven
Drama13
Dec 28, 2012 05:47 PM
ham
May 31, 2006 01:49 PM
lv6l
Dec 14, 2005 04:04 PM
DaveFazari
Oct 11, 2005 01:12 PM
Houston Hatchback
Apr 23, 2003 05:17 PM
