Power steering use it or not?
Old Feb 8, 2006 | 06:59 AM
mjej's Avatar
Default Power steering use it or not?
I have a 1998 hx civic coupe. Just curious how many of yall dirve with out power steering and how much is it a pain in the *** to drive with out it?
Also couldn't i just cut the belt or remove the belt?
Old Feb 8, 2006 | 08:03 PM
mjej's Avatar
Default Re: Power steering use it or not? (mjej)
anyone???
Old Feb 8, 2006 | 08:32 PM
EnzoSpeed's Avatar
After I built my last motor (which took 2 months) I lost my ps belt in the process. I drove for a month like that until I finally found the belt and put it back on.
So yeah, that month sucked. Worst experience ever! Seeing as I'm a bodybuilder, I wouldn't exactly call myself weak, but damn - it's so hard to turn the wheel. It's about 5x harder than a car that didn't come with ps.
So no, you can't just remove the belt.
Old Feb 8, 2006 | 08:35 PM
91DA9's Avatar
Default Re: Power steering use it or not? (EnzoSpeed)
I took the pump and everything off my '91 Integra. It had 15 inch wheels, and was not easy to park, but I drove it like that for 3 years no problems. I am told it is bad on the rack to drain all the fluid and then just loop the lines, but I never had any problems.
Old Feb 9, 2006 | 05:15 AM
mjej's Avatar
the pump is making hella noise and it's making my car idle hella hard. Ii'm thinking it's the bearings in the pulley? Just wondering how much it'll hit my pocket book.
Modified by mjej at 8:33 AM 2/9/2006
Modified by mjej at 9:40 AM 2/9/2006
Old Feb 9, 2006 | 07:06 PM
littleblueb16's Avatar
well i have a crx which doesnt have power steering at it took time to get use to but i dont have a problem at all of course it is quite abit lighter than your coupe i wouldnt suggest doing it. it is your car though but i wouldnt do it if its working leave it alone i learnd that the hard way...lol that poor b16a2
Old Feb 9, 2006 | 07:46 PM
runeminaEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">After I built my last motor (which took 2 months) I lost my ps belt in the process. I drove for a month like that until I finally found the belt and put it back on.
So no, you can't just remove the belt.</TD></TR></TABLE>
^ quit whining you *****! i'm NOT a bodybuilder and i dont bitch about not having power steering. sure it'll suck when the car is below 15mph, but i dont mind it so much. it doesnt suck as much as some people make it out to be. the only thing you have to remember at ALL times is you DONT have power steering, so dont try to park/backup/turn slowly with one hand. i guess it just depends on how much of a little *****/bitch you are and if you can deal with one less creature comfort.
Old Feb 9, 2006 | 10:59 PM
EnzoSpeed's Avatar
Default Re: Power steering use it or not? (runeminaEF9)
No, you ******* retard - driving a car without power steering is NOT the same as driving a car with the power steering belt removed.
Old Feb 10, 2006 | 12:39 AM
scheistermeister's Avatar
ive taken the PS off of a 88 924S and a 87 RX7, yeah its a bitch to turn while stopped but once you are moving its fine.
Old Feb 10, 2006 | 12:52 AM
sQwiReL bOi
Guest
Posts: n/a
ive been driving with PS for the longest time... its not that bad. you get use to it... or at least i did. its actually not as bad as you think it is... i mean im no body builder either, but parking a car with 1 hand and no PS isnt as bad as you really make it. plus no PS is better at high speeds.
deemee
Jul 24, 2009 02:19 PM
AZNracerx1989
Aug 20, 2005 08:04 PM
lsteggy
Nov 19, 2002 08:55 PM
90integraGS
Jun 18, 2001 08:16 PM
