cuts out when reved? & Slow Acceleration
Car: Ok I have A Crx with a d16Z6.
Converted to 0bd1 w low comp piston
(Used to be turbo'd)
Problem: Ok the Car Starts & idles fine,
but if I rev it, It just cuts out.
If i slowly push the peddle it will rev slowly.
Ive tred taking it down the street but it Accelerates very slowly, doesnt fell like it has much power.
I am getting Code 7 TPS
Things Ive Treid:
New TPS & tb gasket
changed the Map senor, Fuel regulator & ecu.
rechecked my vacuum lines.
Im running out of ideas.
Would Adjusting the TPS wrong cause this? or low compression? or maybe injectors?
Things Ive Treid:
New TPS & tb gasket
finally got a volt meter & adjusted my tps to 4.5v runs better but still slow Accel & bogged a few times. but no more codes to give me clues
Powered By Garrett
Jun 25, 2008 09:36 AM
TahitianEG
Aug 7, 2007 11:43 AM
Coltmorris
12
Feb 9, 2007 09:13 AM
