GSR VICTOR x Install help!
Old Sep 29, 2010 | 01:24 AM
Destructive-'s Avatar
Icon6 GSR VICTOR x Install help!
Im installing my new Victor X manifold on my gsr- i went to install the fuel rail, but I noticed the hose that runs from the fuel filter to the fuel rail isn't long enough anymore. Did all of you guys have the same problem or is it just me? If you did, how did you fix it? I already tried loosening it and turning it around but it still won't reach. Any ideas?
Old Sep 29, 2010 | 01:48 AM
mouab18c1's Avatar
Default Re: GSR VICTOR x Install help!
You need to extend the fuel line from filter to rail. Also you will need to bend FPR to fit the hose back on. Or it will be a very tight squeeze.
Old Sep 29, 2010 | 06:50 AM
I thought I'd have to extend the line, but how? The rubber section is crimped to hardline on both sides. Do I replace the whole hose with rubber? But then how do I connect t to the banjo bolt?
Old Sep 29, 2010 | 07:37 AM
kyden's Avatar
get one from an ls.
Old Sep 29, 2010 | 09:12 AM
1992Si's Avatar
Get a dual barred fitting or make one up and some hose clamps and add it to the middle of the oem hose.
Old Sep 29, 2010 | 12:32 PM
The ls one is long enough?
If I go with the barbed fitting route, I don't have to worry about leaks due to the pressure or anything right? It's a walbro 255 with 1000cc injectors. Gonna be making 450-500 hp
Old Sep 29, 2010 | 05:41 PM
Bump
Old Sep 29, 2010 | 06:49 PM
Cmon I know there's a shitlosd of people that have the victor x installed haha- his is all that's holding me back from continuing my build!
Did you guys run in to this problem?
Old Sep 29, 2010 | 07:01 PM
mouab18c1's Avatar
What I did was just have the place where I went to buy new hoses cut off both ends. And When I reconnected them I just used adjustable hose clamps to clamp them down. No leaks.
Old Sep 29, 2010 | 07:17 PM
So just so il clear and don't fudge anything up, cut off both crimped ends from the hardlines, slip on the new longer hose, and just clamp them down?
Old Sep 29, 2010 | 07:43 PM
mouab18c1's Avatar
Yeap.
Old Sep 29, 2010 | 11:56 PM
IN VTEC's Avatar
Stock fuel rail?
Old Sep 30, 2010 | 12:02 AM
Yeah stock fuel rail
Old Sep 30, 2010 | 12:45 AM
mouab18c1's Avatar
Heres my old setup. Stock fuel rail with extended rubber hose. Cant really see it but both ends are held with adjustable clamps.
Old Sep 30, 2010 | 06:59 AM
Oh ok cool, thanks for the pic confirmation mouab18c1, made me feel more confident haha- will be doing this today, stay posted-
LostAndFound
Nov 1, 2008 09:09 AM
LostAndFound
May 19, 2004 10:52 AM
