View Poll Results: To Do it or not to do it?
Yes
26.32%
No
73.68%
Voters: 19. You may not vote on this poll
Custom Gauge Mounting....?
Old Oct 21, 2010 | 12:25 PM
Rob§'s Avatar
Default Custom Gauge Mounting....?
Hey,
I have a 93' Del Sol (https://honda-tech.com/forums/forced-induction-16/93-honda-del-sol-si-turbo-2543783/) and am considering mounting my gauges ( Boost, A/F Wideband, Oil Pressure) above the rear view mirror similar to this picture :
So my question is should i do something Similar but not the exact same ( I in no way will copy someone else's design)
Please comment and vote in the poll
Old Oct 24, 2010 | 07:12 PM
mouab18c1's Avatar
Default Re: Custom Gauge Mounting....?
Why mount it somewhere you cant even see it while driving?
Old Oct 24, 2010 | 07:14 PM
2k.civic.si's Avatar
they make a pillar mount for a reason...use it
Old Oct 25, 2010 | 04:12 AM
Rob§'s Avatar
They make the A pillar because its cheap and easy. hence why EVERYONE has it.
You can see that unless you also think you're rear view mirror is useless because you can't see that.
Thanks for the comments
Old Oct 26, 2010 | 06:22 AM
DB8 RHD's Avatar
Been a popular way for the ford full size trucks to mount gauges for years.
I would either put *important gauges* in pillar or in the view plane of the cluster or pillar and put secondary gauges up top.
Reasoning is focus and depth perception, potential looking up even for that split second could result in a accident, maybe even liability who knows, good luck tho.
Old Oct 26, 2010 | 07:25 PM
horn12007's Avatar
it looks cool but useless at the same time.
Old Oct 27, 2010 | 05:06 PM
Dren's Avatar
It gets them out of the way so you don't have gauges cluttering up the interior. At the same time they aren't positioned so that you can check them at a glance. I'm sick of the pillar pods but they're easy, cheap and an effective location. Another good spot would be on the dash but you'd have to make a nice pod for them so you don't look like a ricer.
Old Oct 27, 2010 | 07:39 PM
madblkscientist's Avatar
its your car so i say do it but i would put the non criticle gauges up there
Old Oct 29, 2010 | 02:56 PM
Eran's Avatar
HT White Ops
Do what I did.
Old Nov 10, 2010 | 07:41 AM
v.i.gsr's Avatar
Old Jul 16, 2011 | 07:31 AM
C_Rock77's Avatar
That's a damn near idiotic place to mount gauges. Eran & v.i.gsr have good suggestions.
Personally, I don't think gauges are there to look cool....they're there to allow you to keep tabs on what's going on with your engine. If you're banging on your car, do you want to have to look at your rear-view to see what's happening? Personally, I think your focus should be between the road and your main gauge cluster. At least with these mounting opitions, the gauge is in your field of view. Yes, "everyone" has pillar pods...b/c they accomplish the most important objectives of mounting gauges.
If you can't see them without moving your head from the road or cluster, it's a waste.
BTW, v.i., where did you get that Din mount? It's nice! I like how they're angled toward the driver.
Old Jul 16, 2011 | 04:06 PM
v.i.gsr's Avatar
Glowshift sells them..
xXB18EKHatchXx
Sep 12, 2009 07:38 PM
hondaboy4life
Apr 6, 2006 12:35 PM
BUCKO5
38
Mar 27, 2005 03:02 PM
john d
Dec 16, 2004 03:57 PM
PA MATT
Jul 14, 2004 02:47 PM
