Main bearing cap replacement
Old Oct 1, 2010 | 08:16 AM
krick182's Avatar
Default Main bearing cap replacement
I have a block with a cracked cylinder. I have another gsr block but it has no bearing caps. can I put the bearing caps from my original gsr block in the bare block that I have? what would I need to do to make it work? Can I use a different upper bearing than lower bearing?
Old Oct 1, 2010 | 09:54 AM
Golden Eagle's Avatar
Default Re: Main bearing cap replacement
Yes you can use it, BUT you will need a LINE BORE. Even if they are the same type of block, NO blocks are Identical. Also, if you wish to put main bolts on your new set up, this is a prefect time to do it.
* Remember, you can always sleeve your cracked block.
Old Oct 11, 2010 | 08:03 AM
NotAJDMFanBoy's Avatar
Sleeving costs like $1k though. Yeah it lets you run crazy boost, but not everyone has $1k to spend when a GSR block is like $250 and don't have to wait for shipping, let alone waiting probably a week turnaround at least
Icon_Ed6
11
Jul 10, 2011 05:05 AM
krick182
Oct 2, 2010 12:30 AM
prodragEG
Apr 13, 2008 03:05 PM
ubreak_ubuy
Apr 28, 2004 10:12 AM
VWkila
Feb 22, 2003 10:47 PM
