vtec help
Old Sep 27, 2010 | 03:37 PM
Sub|ime's Avatar
Default vtec help
I'll try and give enough relevant info hopefully...
The car is a 95 GSR (OBD1). It has a type r engine with a skunk2 valve train and crower stage 2 cams.
I seem to be having an issue with vtec engagement, I was running a GSR ECU with the engagement set at a stock 4500. You could hear the switchover but it was very 'tame' for the lack of a better word. I had a spare p28 ECU chipped with just a type r base map which got rid of my CEL and cured some drivability issues I was having, however now I cannot determine whether vtec is comming on at all. I'd figure with the more aggressive cams it should be pretty noticable as I had a 99 Si with a B16 with a CTR intake cam and the thing just friggen howled after it engaged.
Luckily last night I was able to do some testing with another integra, I swapped the vtec solenoids around (Just the top portion) and still no luck, we tried my ECU in his car and his vtec still engaged fine, tried his ecu in my car and still no dice. The guy that tuned it removed the pressure switch from the ECU as the type r engine doesn't have the plug for it (obd2 engines iirc dont have this)
I have eliminated any possible wiring issues by wiring pin 4 on bank a straight to the vtec solenoid, and I'm at a loss now
Any ideas?
Old Sep 27, 2010 | 10:36 PM
mouab18c1's Avatar
Default Re: vtec help
You need a TUNE, keep running it like that and its gonna take a **** on you
Old Sep 28, 2010 | 02:34 AM
chewyv's Avatar
pm4nudes
Banned?
Sub|ime
Sep 27, 2010 04:32 PM
Sub|ime
Sep 27, 2010 04:22 PM
crush
Jul 18, 2005 05:03 AM
NightHawkC5
Feb 27, 2003 11:14 AM
