cam degree kit...
Old Oct 5, 2010 | 06:41 PM
cibao2ner's Avatar
Default cam degree kit...
where to buy it...wat do i need a dial indicator,degree wheel and what else?
Old Oct 7, 2010 | 12:02 AM
95skunkedgsr's Avatar
Default Re: cam degree kit...
summit racing ...xenocron < probly spelled that wrong
Old Oct 7, 2010 | 08:37 AM
unusual71's Avatar
the summit kit is pretty good for the price. good buy if your going to use a bunch of times or if you can share it amoungst friends etc.
Old Oct 7, 2010 | 01:17 PM
a1320addict's Avatar
belben kit from xenocron
Old Oct 8, 2010 | 08:20 AM
sugarfree135's Avatar
if you're going to get it dyno'd anyway i don't see the point in spending $300 on one unless you're checking p2v or v2v clearances
Old Oct 9, 2010 | 07:15 PM
blackcracker's Avatar
http://www.xenocron.com/kseriess2000...3a95c2375a88d6
You should always check P2v and V2v when building a high dollar,high horse power engine.
Old Oct 9, 2010 | 09:02 PM
raverx3m's Avatar
but it would save time on the dyno.
and in my case it helped to set correct timing sinc ei will have to drive about 60 miles to the tuner id rather do as much as i can before driving it.
Old Oct 9, 2010 | 09:04 PM
raverx3m's Avatar
i do personally think that the extra TDC dial gauge is not necessary.
you only find the TDC once and then you dont really need it. if they could sell a kit with only 2 dial gauges it probably be more popular.and affordable
Old Oct 12, 2010 | 03:21 PM
xenocron's Avatar
I've thought about selling it with only one...I just dont like confusing people with too many options, sometimes that creates more work
Old Oct 12, 2010 | 04:24 PM
raverx3m's Avatar
or maybe a piston stop instead of tdc dial gauge. because i spent 98 dollars on summit racing kit but wasnt too happy about it.
if it was just a bit cheaper i would spend the extra few bucks on your kit, but i was already past my budget so had to go with a cheaper one...
but be realistic, most of us will only use it once or twice,and its kinda hard to justify spending over 200 dollars on a tool you only use once or twice( if that). how much does that gauge cost alone?
its only one more option, can be named DIY cam degree kit or something like that.
Old Oct 15, 2010 | 04:24 PM
Garage 808 Hatch's Avatar
Xenocron, leave the kits how they are, they work perfect.
Old Oct 15, 2010 | 05:33 PM
raverx3m's Avatar
lol ok
Old Oct 18, 2010 | 04:27 PM
h22 civic's Avatar
thats where i got mine
vipersal
Jan 23, 2014 06:40 AM
GoodSkoolRevltn
15
Nov 21, 2013 03:38 PM
tony413
Aug 17, 2007 03:01 PM
ITRnorway
Sep 20, 2006 04:34 AM
Acura_I-RS
Jul 17, 2003 08:32 PM
