DB1 RS power window conversion questions??
Old Oct 16, 2010 | 10:46 PM
jdmbotnik.'s Avatar
Default DB1 RS power window conversion questions??
Alright so heres my problem. I just tried converting my windows from manual to power. I plugged all the harness's in and I made sure I had all grounds set from the two under the dash on the driver and passenger side to the door sensor grounds. So, after all of that... I try to see if the power windows work... well this is where my problem starts. My driver side window works perfectly and the power locks work fine as well. BUT when I tried my passenger window and even my passenger rear window for confirmation that it wasn't just the passenger... it didn't work. when I plug in my power lock harness to the power lock on the passenger door. my seat belt beeping stops and when i try to roll the windows up and down, my defogger switch blinks and I get no reaction... same with the passenger rear. Then, when i unplug my power lock switch, my seat belt beeping starts again and sounds normal and the defogger switch isn't acting weird. Sorry for the long summary but can anyone help me with this problem? please it'd be greatly appreciated. Thanks in advance.
Old Oct 17, 2010 | 06:25 AM
fcm's Avatar
fcm
Old Fart
Default Re: DB1 RS power window conversion questions??
Obviously something is miswired, because other circuits, [defog, chime] are effected the problem is most likely a grounding issue. 94
dwardo55
Nov 20, 2012 07:45 AM
96blkteggy
Mar 19, 2011 03:19 PM
mugenpower92ls
Mar 23, 2007 05:50 PM
IDriveHonda
11
May 12, 2005 09:52 AM
haloseven
Sep 18, 2001 07:41 PM
