Motor wont start Help PLs
So i just installed a new engine i could not get it to start though.
actually its a d16y8 block with a d16z6 head but that shouldn't matter basically same as any d16 motor
so the symptoms are it cranks just fine but wont start and i do not hear any combustion at all
what has been done:
according to my timing light it has spark
has fuel up to the fuel filter(was leaking so i am getting new crush washers, but i dont think this is the problem it should at least try to start.)
Double checked my timing belt was on correct
Pulled dizzy cap saw the rotor is facing #1 at TDC and double checked firing order 1 3 4 2
next:
replace crush washers
check compression
any other ideas guys? one of my major questions would be how to i test the injectors? because i know there is fuel to them and i am also getting spark.
what has been done:
next:
check compression
Do you have 12V+ at the injectors, [wire that is the same color on all 4 injectors].
Test and make sure there is 12V+ to all injectors when ign. key is in run and start. 94
i will check the voltage when i get home. but i do have dsm injectors with the resistor box. so voltage should be lower. also i had this resistor box/ injector setup on my last motor and it worked fine.
Yeah, I think you need to get a noid light and make sure you have injector pulse. Just as a quick test before you buy a set of noid lights is to just spray alitttle carb cleaner into the throttle body and see if it tries to start. If not you have some other problems.
ORguy
10
Mar 22, 2011 05:25 PM
