b16 emissions problem
Old Oct 4, 2010 | 11:35 AM
vLad11591's Avatar
Default b16 emissions problem
I cant seem to pass emissions in NJ.... I have a jdm b16 with a p28 chipped ecu, put in 93 octane, a cpl quarts of oil, semi-new o2 sensor, and my catalytic converter is brand new along with brand new custom exhaust (2.5 piping, magnaflow cat, vibrant muffler) and i still failed.
My regular idle passes with flying colors, but my high idle failed. HC:645 which is extremely high since the standard is 220... the next thing im going to do is ignition timing, but if that doesnt work idk what to do. maybe its my ecu? any help would be appreciated.
Old Oct 4, 2010 | 12:26 PM
vLad11591's Avatar
Default Re: b16 emissions problem
bump ttt
Old Oct 4, 2010 | 12:32 PM
kyden's Avatar
is it a random tune on the ecu? o2 enabled?
Old Oct 4, 2010 | 03:24 PM
vLad11591's Avatar
well from what my street tuner says.... its a p30 basemap.. with basic functions such as rev limiter and 2 step etc... he didnt mess with the a/f ratios or any of that. o2 is enabled... but it can be disabled, but the o2 sensor when enabled no check engine light so the o2 sensor is fine.
Old Oct 4, 2010 | 06:12 PM
vLad11591's Avatar
bumppp
Old Oct 6, 2010 | 07:25 PM
Scott_Tucker's Avatar
You need to post the other exhaust gas levels. Without them you are not telling the entire story.
Old Oct 9, 2010 | 06:51 PM
honda fossil's Avatar
what was the nox level?????? and if you are play with your tune just lean it out take the test and chage it back
OldSchoolFool
May 21, 2015 02:31 PM
prostreetonline
May 23, 2007 09:06 AM
racekar
Sep 3, 2004 06:34 PM
90hbvtec
Dec 5, 2003 07:42 AM
johnzm
10
Apr 12, 2003 06:59 AM
