Oil colored water
Old Oct 12, 2010 | 09:04 AM
deucedeuceEK's Avatar
Default Oil colored water
So I just put an ls motor in my teg and went to drain any old oil out. I recieved a huge suprise with it being super watery! I wanted some advice on what you all would do in this situation. I was planing on buying some thick oil and build some oil pressure and then run a compression test. And obviously if it came out all screwy change the head gasket. But if the compression came out fine go ahead and start it up. Then drive it around the block and change the oil again.
subtlecuddle
Aug 4, 2015 08:52 AM
r1ch1e
Jan 16, 2007 12:10 PM
dabomb
Nov 4, 2006 04:42 PM
jvonb
Dec 3, 2005 03:02 PM
Mikes94
Jul 15, 2001 03:56 PM
