block help plzzzz
Old Sep 29, 2010 | 10:03 AM
ghosthatch's Avatar
Default block help plzzzz
ok so my b20 exploded
eagle h rod went through the block. pistons are more than likely done. all rods bent. crank is unknown in condition
i have a bare gsr block and was wondering if i could use the b20 crank, bore it out to 84mm and get new pistons and rods for b20 spec. can this be done without a problem or do i need to buy a new b20 block?
i know the deck height is only a slight difference. i dont really know much about stroke but i know theyre different. is that just bc the pistons/rods?
also would i still be able to use b20 rod bearings or would i use the gsr?
Old Sep 29, 2010 | 11:20 PM
ghosthatch's Avatar
Default Re: block help plzzzz
please?
Old Sep 30, 2010 | 04:16 AM
kyden's Avatar
getting a gsr block to 84mm would require sleeves.
Old Oct 1, 2010 | 08:10 AM
ghosthatch's Avatar
why is that? i didnt need sleeves for the b20.... well did for what i did to it but it was just fine. i thought the blocks were essentially all the same
ghosthatch's Avatar
still havent gotten the answers i need
Old Oct 1, 2010 | 10:32 AM
Golden Eagle's Avatar
B18 A/B/C all start out @ 81.MM
B20's start @ 84.MM
Old Oct 2, 2010 | 10:11 AM
ghosthatch's Avatar
i know what each blocks piston size is. thats not my question. i already said id bore it out to 84
Old Oct 2, 2010 | 10:21 AM
Drive 4 fun's Avatar
Too much boring, not enough cylinder wall thickness.
Old Oct 3, 2010 | 11:47 AM
ghosthatch's Avatar
what difference does the wall thickness mean from boring it??? of course you could bore it to 84mm. im not asking about the bore. the crv block is already 84mm. they are essentially the same blocks, just different bores.
people telling me things i already know and not what im actually asking
Old Oct 3, 2010 | 12:00 PM
cibao2ner's Avatar
he already told you....82mm is the max you can bore a b18b/c block...get a new b20 block
Old Oct 3, 2010 | 12:05 PM
"the crv block is already 84mm."
The block is not really 84, but the cylinder bore is. It is an insert to the block. That is why people say resleeve, or recylinder to get the 84.
Old Oct 3, 2010 | 12:13 PM
ghosthatch's Avatar
what? of course not the block itself
isnt a b20 just a larger bore ls? its supposed to be identical for the most part. what difference would it make for the gsr
Old Oct 3, 2010 | 12:36 PM
2k.civic.si's Avatar
go ahead and bore out the gsr to 84mm and let us know how that goes for ya =P
Old Oct 3, 2010 | 12:42 PM
ghosthatch's Avatar
well? what difference is it? dont be smart asses. if you have a legitimate reason tell me
why cant i bore it if the blocks are all essentially the same, minus the squirters and girdle in gsr and the difference in stroke and bore? im sure the walls are still the same thickness as a b20 if you bore it. b20 walls are thin as it is. b20s are reliable it was just a dumb call on my part to max it out for a bit of a distance. so if you are telling me that the walls are too thin just bc its 84mm it doesnt help my question.
Old Oct 3, 2010 | 01:33 PM
Not trying to give you a bad time, but explain. You will get 84mm in the b18 at about the outer edge of the cylinder wall, not enough left for strength, and the b20 starts at 84 and then has an appropriate wall thickness left. It is a different cylinder or sleeve in the block to start with.
Old Oct 3, 2010 | 01:39 PM
ghosthatch's Avatar
is that really true? damn
Old Oct 3, 2010 | 01:48 PM
b20 blocks are dirt cheap anyway....just buy another one
Old Oct 4, 2010 | 12:08 AM
ghosthatch's Avatar
well if i didnt need to spend the money and could get the gsr squirters and block girdle for higher rpm revs it would have been awesome. thats all
thanks
lakai_19
Mar 12, 2008 07:51 PM
clutch6racerone
Apr 26, 2007 05:34 PM
pootie.teng
14
Aug 25, 2004 04:50 PM
all motor b20b
May 25, 2004 02:51 PM
PowderB16
Jan 30, 2004 10:57 AM
